    Page 10 of 15 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 LastLast
    Results 181 to 200 of 289
    1. #181
      Apr 2010
      Jersey Shore
      Finished plumbing the ABS (minus the F/R inputs)
      Beginning mock up of my rear ST40's... plan so far is to use a C5 Corvette front rotor and an IPSCO spot caliper for parking brake
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
    2. #182
      Dec 2010
      Charlestown NH
      yo kiddd, get a bettah camera!
      https://www.pro-touring.com/showthre...-Touring-Truck
      DMP Fabrication LLC
      Follow me on Instagram for welding and truck progress! - Americangraffiti
    3. #183
      Jun 2014
      Quote Originally Posted by the dan View Post
      Lmbo! But for real though
    4. #184
      Apr 2010
      Jersey Shore
      Corvette> new phone
      Horrible quality pics will hopefully be ending soon
      I have my other guy at the shop take pictures on his phone then send them to me for the time being...
      3D printed C4 corvette Stoptech ST40 caliper bracket for mock up
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    5. #185
      Apr 2010
      Jersey Shore
      Brake lines complete... next up is fuel line. Trying to figure out how to run (2) -8 hardlines around cage mounts, through crossmembers, away from suspension parts AND be serviceable with the body on the car is proving to be a bit difficult!
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    6. #186
      Dec 2010
      Charlestown NH
      Body-off brake line service is mint!
      DMP Fabrication LLC
    7. #187
      Apr 2010
      Jersey Shore
      ABS bracket from DMP Fab showed up... Aluminum bracket with a .030 heat shield underneath to protect from potential sidepipe heat. The abs unit will sit on a strip of rubber to help isolate from vibration
      Fuel lines and tank mock up... Im using Earls pro-lite 350 -8 braided from the rear frame rail to the kickup. The plan so far for the tank is to have it come down to the bottom of the body and follow the body line as far back as possible to help seal off the open rear underside for aero. at 38x10x15 its just shy of 25 gallons.
      Mockup hardline
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    8. #188
      Dec 2012
      Project: Love 69 - My Corvette Build Thread
      So glad to see this project moving again--looking good!
    9. #189
      Apr 2010
      Jersey Shore
      Starting on belly pan tabs before I go any further with the (hard) fuel lines since I will be routing the lines around the tabs. Im using Dzus fasteners/plates/springs from Earls... They were the only company that I could find with a diagram on how to choose what parts would work together (ie: spring height w/ compression, plate sizing, fastener reach) They also have "lightweight" plates with a few extra holes in them. Am I being anal enough about weight yet??
      The wood is just there for mockup purposes... The final pan material will be .25" carbon fiber honeycomb
      Quote Originally Posted by Aficionado View Post
      Thanks! It feels good to be moving again!
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    10. #190
      Apr 2010
      Jersey Shore
      These bends took much longer than I'd like to admit and they still arent perfect, but Id like to get the body back on soon so I think it will suffice considering it will never be seen...
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    11. #191
      Dec 2010
      Charlestown NH
      Came out perfect! If you want. A bigger heat shield let me know. I should have taken into account the larger body
      DMP Fabrication LLC
    12. #192
      Apr 2010
      Jersey Shore
      You made the shield the correct size, I cut it down too small (whoops)
      Im ready for fuel tank and brake bracket fab whenever youre ready!
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    13. #193
      Apr 2010
      Jersey Shore
      Getting very close to final assembly! Got the last parts back from powdercoat; Picking up the frame from the bodyshop tomorrow morning. While waiting, I detailed and painted what I could.
      Before I had it blasted and painted I had some steel tubing welded in with AN bungs so I could run the fuel lines through the frame. Under the crossmember would have been too low (and interfered with the belly pan) and over would have prevented me from ever removing the lines if I needed to once the body is on.
      Removed all the casting seams and radiused (sp?) some of the sharp edges. Painted silver, and had the swaybar bracket powdercoated black
      Control arms powdercoated
      Hard to get a picture that represents the chassis color well... it looks slightly more gray than the photos show. Bumper brackets, chassis and firewall will be this color
      Diff painted with Energy Suspension poly bushings installed
      SKF rear wheel bearings/hubs were modified by DMP fab for 5/8 wheelstuds to match the front TrackStar hubs. They should be here shortly along with the final production StopTech caliper brackets
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    14. #194
      Apr 2010
      Jersey Shore
      Picked up this morning, took a "personal day" to start assembly
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    15. #195
      Apr 2010
      Jersey Shore
      little more progress...
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    16. #196
      Jan 2014
      Austin, TX
      Nicely done....I dig the super clear routing! I've got a '64 that I'm about to dig into, to include the 4 wheels disc conversion. Unfortunately, with the body not coming off the frame, running clean brake and hard fuel lines to the rear is going to be a challenge.
    17. #197
      Mar 2013
      Detroit Michigan
      pumped to see the progress on your car.
      makes me want to start all my frame mods and cage build. How long the car is down is the main thing keeping me from starting. I can only imagine how ready you are to drive it.
    18. #198
      Sep 2012
      CT
      Awesome ride! Dan does great work
      1966 C-10. Porterbuilt C4 front, 4 link 9" rear, Ridetech coilovers, Built 383/Muncie
    19. #199
      Apr 2010
      Jersey Shore
      DMP Fab (The Dan) just sent me some pictures of the competed brake/hub assembly... SKF hubs with Strange Engineering 5/8 studs, and custom ST40/ C5 rotor brake caliper bracket. Cant wait to get these in my hands and on the car!
      Quote Originally Posted by FLYNAVY53 View Post
      Thanks! I couldnt imagine doing this with the body on... I had a hard enough time doing it like this!
      Quote Originally Posted by User-C3 View Post
      I am beyond ready to drive this thing... but I really enjoy the design and assembly of it as well. My one word of advice, buy a second frame and do the mods to that one so you can still drive the car! I should have done that with mine
      Quote Originally Posted by timmytimm3 View Post
      Thanks! Dan is the only person Ive met that I can give him a project and I wont have to worry if its being done right... Everytime I get a part back from him its even better than I envisioned.
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    20. #200
      Apr 2010
      Jersey Shore
      Getting closer!
      (caliper is on the wrong side in pics!)
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
