      El Dorado Hills, CA
      Z-bar hitting headers, help please....
      Hey everybody, I have a huge problem. As some of you know I have a 68 Camaro with a 468 BBC in it and I am putting in the TKO-600. Full converson from AT to stick. I am in the process of mock up to measure the rearend length, but I was playing around with the Z bar and I noticed it was going to hit the headers. I have Hooker Comp headers made for my Camaro, and I called Hooker and they said it should bolt right up. Well mine is not. Has anybody else run into this problem? If so how was it fixed? Also I am running solid motor mounts and still have the SBC frame mounts. But from what I can tell the Z bar will hit either way.... Or does the Frame mounts move the motor that much? I can't even draw a line from the block where it is supposed to go to the Frame bracket because the headers are there..
      Any help appreciated...
      __________________
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      i have the same headers with a BBC and with a quick mock up it looks close, verry close, i didnt play with it too much because i realized i F'ed up and forget the clutch fork piviot ball, and pulled everything back apart. ill let you know what i end up with in the next few days, unless you have alredy solved this problem, then please share with the rest of us.
