      Los Angeles
      Frame Fitment Question
      Are all the G body Frames the same?
      Reason Im asking, I want to build another car but cant afford to dump a lot of money in a project right now but I can take advantage of my local pick a parts half price days and start building another car one part at a time.
      There are a lot of G bodys in the parts yards with good solid frames to be had. My plan is a 78-80 Monte Carlo but if I cant find one of those Can I use a Malibu, Pontiac or Olds of the same years and have it still slide under the Monte?
      The rule is measure twice and cut once. My problem is I still measure with a mic and cut with an axe!
      Loganville, GA
      The Regal, Cutlass and Grand Prix frames will interchange, as long as they are two door as well. Not sure on the 4-door, but El Camino and wagon frames have a longer wheelbase and thus won't work.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Los Angeles
      Thanks Randy.
      Jun 2011
      St. George, Utah
      Only Elky's have extended wheelbase as far as what I've researched. Wagons have slightly different rear frame rails because the gas tank was re-designed to allow a spare tire well next to it. My understanding is that a 4 doorsand 2 doors have the same frame.
      To answer your question, all 2 doors should be the same platform... I think. You can google it or maybe check gbodyforum.com or gbodycentral.com
      Either way I don't thingk a G-body frame will fit under a Pinto. ;)
      SRD on Facebook
      79 Cutlass wagon build
      Los Angeles
      Quote Originally Posted by SRD art View Post
      Thanks. I have a post over on the Gbody fourm.
      This is going to be a 78-80 Monte, I already did a couple Pintos, Want to get back to my high school days with this one.
      500 caddy, Muncie 4speed, a bit of setback and big sticky tires
