Results 21 to 21 of 21
Engine Ideas? (sorry for posting in the wrong section)
I posted this in the engine section a while back but got no replys so sorry for posting in the wrong section but I am ready to spend money and would like some suggestions. I am building off an 83 454 block and want to come up with a nice forged reciprocating assembly that will handle 1000 hp. I am thinking about an eagle 4340 crank and rod setup with arp rod bolts and 9310 wrist pins, je forged flattop pistons with hellfire rings. I will be using open chamber oval port heads for now. Should I stay with the stock stroke or go with a stroker kit? What head gaskets are good to use and should I o ring the block? It will be turboed and will be seeing 15 lbs of boost on occasion. It will have a 4L80E trans behind it with 3.08 gears and I would like to get 20 mpg out of it cruising if possible. Will going with a stoker kit make any difference on fuel economy? I am taking the block to the machine shop monday so I need to get my parts list finalized asap.
Thanks in advance,
Mike
Turbos, 1700.00
Hot Side, 1500.00
Cold Side, 1,000.00
Fuel System, 1,000.00
The look on the face of whomever the passenger is when the tires break loose at o say 70 mph or so........priceless
