    Thread: Valve Stems?
      Vincennes, IN
      Valve Stems?
      I need help finding a valve stems for my 18x12 rims with a flat lip. Running 6p baer brakes and the stems im using hit the caliper. Is there a smaller one im needing to use with this set up?
      Thanks for your Help! I should Add I have Intro two piece wheels where its half way back inside the rim. Looks like a step lip behind the face of the rim. Dose that help?
      Feb 2010
      ARIZONA
      Maybe you can run flush mount stems. They can be a bit of a pain since you need to install an adapter to check pressure or air up or down.
      http://www.summitracing.com/parts/MRG-5102/?rtype=10
      Larry
      67 Camaro, 350 SB, Custom A-Arms & 3-Link
      My Build https://www.pro-touring.com/showthre...LOVE-67-Camaro
      Orangevale, Ca
      Search BR Motorsports, we use these on the race car and are very low profile and work great. Might work for you and the price is right...
      Bret Ervin
      Vincennes, IN
      Great! Thanks guys ill look at them!
      Mar 2004
      Mid-Michigan
      I have to do the same thing on the van. I will probably pick up a set from Speedway. 12 bucks
      http://www.speedwaymotors.com/Steel-...of-4,5479.html
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
