    Results 1 to 9 of 9
      Jul 2010
      Monticello, MN
      ATS/AFX factory height spindles
      SOLD
      http://www.americantouringspecialties.com/FAQ/
      Here are a couple points pasted from the above reference:
      I have the Guldstrand Mod or DSE coil over system on my car. Which AFX spindles should I use?
      We recommend the stock version of the AFX spindle for use on the F body in these instances. A tall spindle could be substituted in the event of a race only vehicle, as the camber gain is too aggressive for street driving.
      I have an aftermarket rack and pinion unit installed. Can I still use the AFX spindle with this steering setup?
      Yes. The AFX spindle has a bolt on steering arm, which can be replaced with aftermarket arms designed for rack and pinion conversions. This includes the BRP, Flaming River, and UniSteer conversions.
      I will include a set of the BRP HotRods Steering Arms ($250 new) mentioned above to someone buying the spindles for an additional $50. I have them listed at $100. https://www.pro-touring.com/showthre...rms&highlight=
      First “I’ll take them” time stamp gets it whether via PM or posted.
      Listing item on PT.com and Lat-G.
      Mar 2012
      Orange County, California
      PM sent
      Feb 2012
      WOW this looks like a great idea.......guessing I'm second in line though
      Jul 2010
      Monticello, MN
      PM's replied. Currently still available.
      Mar 2012
      Quote Originally Posted by Roberts68 View Post
      Check your box.
      Thanks robert
      Mar 2012
      Robert,
      Thanks again for the spindles. It's always tough to send $$ trusting that you will get what you are paying for. Anyone buying from Robert will be in good hands. Great communication and follow through.
      Jul 2010
      Monticello, MN
      Thank you for that Efrain. It was a pleasure doing business with you as well.
      Jul 2010
      Monticello, MN
      Efrain, you need some brakes to go on those? Fill them 18's up real nice...?
      Let me know what you think, it has been awhile.
      Mar 2012
      LOL. Those are nice but as it turns out the 14 inch will bee too much for my wheel since my valve stems are 90 degrees and on the back side of the rim. I ended up using some Baer's that I had laying around (basically the C5 PBR caliper) along with some C5 rotors from Pep Boys.
      By the way those spindles worked out well. Thanks and good luck with the sale.
