    Results 1 to 12 of 12
      Aug 2011
      Nor Cal
      Best solution for getting the front end lower?
      I have a 66 Chevelle Im finishing up... Tried rims on it yesterday and the front end still looks too high. I have QA1 coil overs bottomed out in the front and cant find a reasonable solution where I can still raise em (dont want a super hard ride), and not have a car that sits weird. I will post some pics later, but for now any ideas? Solutions that are not going to cost an arm and a leg?
      Aug 2011
      Nor Cal
Size:  202.3 KBName:  IMG_1700.jpg
      20's all around... What is I run 18's in the front?
      Aug 2011
      Nor Cal
      Aug 2011
      Nor Cal
      By the way the car hasnt been sanded or anything. Straight out the booth. So I dont wanna hear nothing bout orange peel...
      Anyways I keep thinkiing smaller front rim? But if its the same overall diameter will it matter? Any ideas Please!
      Beach Park IL
      Finish putting the car together. You have a lot of weight to bolt on yet, it wouldn't suprise me to find that when the car is all assembled you will be turning the coilovers up.
      18s will look tiny with the 20s in the back. Stick with what you got and be patient, it will work out just fine.
      Jun 2009
      Central FL
      Put a hood on it.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Nov 2010
      yea put it together first and all the weight and it should drop it down... if all else fails, run a lower profile tire upfront. would be a lot cheaper than going and getting two new rims and tires
      Nice car though, it looks great
      68 Camaro RS twin turbo
      Slow Lifted Jeep No TURBO :(
      Randal F
      Aug 2011
      Nor Cal
      The hoods fiberglass... and interior is stock. How much weight will I gain by doing that? Also I heard a while back that coils wont sink or lower over time, that the adjustment is made with ride height? Dont know if I heard that correct or if dude had any idea what he was talking bout? Will they?
      May 2002
      Northern California
      I agree, all that stuff will add up. Glass, regulators, interior and hardware can.
      If it needs does need adjusting, wait till you get a few miles on it to let the suspension settle a bit. It really depends on what components are used and combinations. I have had cars go down as far as 1 1/2" and some just a 1/2". Also leave your control arms a little less than snug, tighten up on a drive on rack or on your frame machine.
      So you are running the QA1 half coil over set up right?
      BTW, the car looks kick ass!!!!!
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oct 2003
      Arvada, Co
      It looks like you still have at least 500 lbs to put on the car in the glass, interior, hood, engine fluids...I am with others. You may be trying to fix a problem that does not exist.
      Brian
      Aug 2011
      Nor Cal
      500lbs!?! Jeez, maybe I was gettin ahead of myself... Gratzi!
      Put a few miles on it first too. The springs will settle a little.
      Nathan Shaw
      71 Nova, 1000+whp 5.3, 8 second autoXer.
    Tags for this Thread
