      Glendale, Az
      TKO speed sensor hookup
      Has anyone used the speed sensor on a tremec to send a signal to an autometer electric speedo? AutoMeters website states that one of the sensor wires outputs dc voltage. So does that mean that the other wire would need a 12v supply?
      i have. im not sure of the wires but i will look tomorrow.and yess you need a 12v source if i remember correctly
      Glendale, Az
      any help guys? someone has to have hooked these speedos up this way.
      Pittsboro, NC
      You are correct. One goes to 12v on tach and the other to the OUT on the tach. If I remember correctly, there are two outs on the autometer tach. One is VSS OUT (something like that) and the other is standard DC out. If you are not using a computer, then use the standard DC out. If you connect to the wrong out the speedo will give you a crazy speed reading. Ask me how I know that.
