      Jul 2010
      Monticello, MN
      BRP Hotrods Steering arms
      These beefy billet bits came on a set of ATS Spindles I bought.
      They should work with anything that uses the same steering arm if you want to incorporate a rack/pinion. I am keeping my steering gear.
      They are Billet Steering arms that allow the use of a 1998-2002 F-Body rack & pinion steering according to BRP.
      They are supposed to shave about 6 pounds compared to iron arms.
      "BRP steering arms will help you connect the late model GM power rack to your existing spindles. Each steering arm is machined out of a single piece of aluminum for maximum strength and milled down to specs."
      They retailed for $200 and there are a few competitors offering similar for that price and up.
      Please note that they have some contact marks on them. I thought it best to leave them as is but a guy could probably do some cosmetic filing/polishing if your inner spindle area is likely to undergo cosmetic scrutiny.
      $100 plus shipping.
      Thanks for looking.
      Robert
      Jul 2010
      Monticello, MN
      BTT.
      These will fit OE spindles and can also be used to address bumpsteer using a baer-tracker style setup with a little ingenuity. Shed a little weight and get some tuning ability.
      I also have them listed as part of a package deal with the spindles.
