    Thread: audi seats
      CT
      audi seats
      I have a set of 2002 audi A4 seats that I might use. Does anyone have the wiring diagram so I can find out which wire is for what.. There are 4 sets off plugs coming off the seat..
      Bryan, 69 nova LS3 w/T56 Ridetech subframe
      Oct 2006
      McKinney, TX
      Get a battery and some wire and start checking the circuit...it will take a bit of time, but if you can't come up with a wiring diagram it works
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      CT
      Only thing I'm worried about is there is a side air bag and not sure if poking the wrong wire will set it off..
      Feb 2011
      South of Sydney, Australia
      Country Flag: Australia
      The side air bag will have its own plug yellow or orange in color with 2 wires, blue and brown if memory serves me. It's been a while though.
      Also brown is always ground with Audi
      And yes if you put 12volts to the air bag it will deploy
      " If it doesn't have a MOTOR, it's not a SPORT."
      Dajen.
      CT
      Thanks for the info... helps alot
      Feb 2011
      no worries. if you need to know anything just ask. I still have some contacts at Audi.
      Dajen.
      Oct 2006
      McKinney, TX
      Law requires that any and all airbag connectors are yellow. Stay away from those and you should be good to go.
      My build Beast
      Mar 2014
      Hey there, quick question for you. I also have a set of audi a4 seats from a 2002. What are you using for frame rails/ mounting brackets? Thanks in advance
