      California
      LY6/6L90E Questions..
      I just found a low milage LY6/6L90 for a great price with low milage. Has anyone done this swap? What problems were encountered? Would this be a good alternative to my LQ4/4L80 swap? How much trouble is the 6L90. Any help you guys can give would be awesome!
      Dec 2007
      Probably need some more specific specs here like what is it going in? Because of the truck manifold it may not fit in some cars would be one potential problem. You can go LS3 manifold but it is not a simple change, some of the accessory drive is in the way and the MAP sensor may have to change, thus a change in the programming. The trans it huge, even bigger than a 4L80e so cutting out the trans tunnel will probably have to be done also. But if it is cheap, I'd do it, I think it is a great setup. VVT with that trans will make it quick. Try to get everything you can with that setup: accessories; harness; MAF; seriously anything and everything you can get, get it. I picked up an LY6 but with no harness; accessories; MAF; various sensors....the stuff adds up.
      Jon
      California
      Its going in my 69 GTO, I have seen chevelles done with teh truck manifold and there is still room. Trans change is going to be easy Ill just cut the tunnel and re weld it. My main questions are about the wiring, can it be brought down to a 4 wire standalone system like the LS1? How much of a pain in the arse will the VVT make it to put the turbo setup on it? The engine is complete, all the accessories and sensors are there the only missing parts are the ECU and Pedal. Both got crushed along with the rest of the car.
      Mountain Springs, Texas
      Speartech has a harness and ECU.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Dec 2009
      San Diego, CA
      I had Speartech modify the factory harness for my swap. Only issue I have is with a transmission code that is not Speartech related. I used EfiLive to ignore it and the truck drives flawlessly.
      Dec 2007
      Oh yea, you can definitely bring down the harness, I had this guy do mine.. http://modernvintagesystems.blogspot.com. I was quite happy, he is extremely knowledgeable. I looked into the VVT with turbos, but can't find much on it, I think the programming becomes quite complex. To learn more I would find what the Honda guys are doing with VVT and turbos. I did find a guy running a VVT with supercharger and he was driving it but he continues to have tuning problems. Since you don't have an ECU and a pedal, you can get a pedal that fits, such as the corvette, and have the harness guy set it up when he rebuilds it and the programmer will do the rest.
      California
      I talked to mast today and they told me to use their VVT HO cam and springs. The guy I talked to also told me 650-700 HP easy with 10lbs of boost and still use the VVT. I also talked to a few different places about the wiring harness and all want to do the conversion for 500.00+ I want to do it myself. Anyone have any good info on converting the stock harness to a standalone 3 wire setup?
