      Mar 2012
      ls1 swap help needed
      I have a 85 S-10 Blazer that im wanting to put an LS1 in it so my question is were can i get the parts to swap it over. If anyone knows were to get everything i would really appreciate it thanks.
      Mountain Springs, Texas
      Check over on ls1tech.com in the conversions and hybrids forum.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2011
      mass
      the s10 blazer is a shorter wheel base, then the reg s10 pick up so there is 1'' mounting pas welded to the frame of the blazer, so this makes motor sit higher and some of the parts might not work. hope this helps
      Sep 2009
      Port Richey Fl
      Current Performance Wiring does a lot of LS1 conversions. www.currentperformance.com
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
      Houston, TX
      Check out s10forum.com. They have an entire section dedicated to LSx swapped trucks and the sticky info will more than get you on your way.
      And Jared at Current performance will build you a plug and play harness to get that truck running once you get the motor in. I DD a 91 s10 w/ a 2005 5.3/700r4 combo. Any specific questions hit me up.
      Asa Walker
      Houston, TX
      Jul 2011
      I know speedwaymotors.com has a decent amount of things for LS swaps. I ordered some nice motor mounts, fuel system, computer mount and fittings from them for my 77 El Camino 5.3 swap. I know they have harness' too.
