    Results 1 to 20 of 40
      Jun 2010
      Georgia
      Sequential LED's for Cutlass, why doesn't anyone make them?
      Just wondering why there are a dozen kits out there for the Mustang and Camaro, but nothing for the Cutlass? I know I could probably adapt a kit to work, but I would like to see a bolt-in, affordable LED kit for the Cutlass' models. I spent some time looking over the last few months, off and on, and haven't found anything for them yet. Seems that once you make a kit for the Mustang or Camaro, adapting the design to work in the A-bodies wouldn't be a far stretch.
      Sep 2011
      Lake Ozark Mo
      I am looking into this for my firebird. If I'm remembering correct there needs to be at least 3 tail light per side to make it work. If I can find the link ill share it with ya.
      Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
      Jul 2009
      Grand Rapids, MI
      Connect with spaghetti engineering (Digi-Tails). They have begun building them for arguably the smallest, and cheapest, automotive market on the planet, Mopar, and I picked up a set for my A-body. Speak with them personally and see what they'll do.
      Will Ellis
      Build Thread
      California
      Sparky, your Olds and my Pontiac are not popular enough to get them yet. I still have to touch base with you about your bezel (sorry, things have been busy)
      Jun 2010
      Georgia
      Quote Originally Posted by wellis77 View Post
      I emailed a few times and used their online contact us link, and never got any response. Actually, same thing with about 4 or 5 other companies I contacted.
      Quote Originally Posted by SShep71 View Post
      Shame, as there really are enough of them still out there to make great money on. For the bezel, thanks, let me know what you come up with.
      Oct 2007
      Atlanta
      Sparky,
      we should match up the actual light housings on your car to mine. I've the digitails on mine, and basically all they do is screw an LED board into the housing. So all that would have to be done is to get the LED board the right size/shape to match up to your light and you're good. Probably sounds easier than it is, but it shouldn't be rocket science either.
      FYI, I called them 2 weeks ago and they responded back to me very promptly. My right tail had one of the boards failing and they sent me a new one that day. Great customer service.
      Sep 2011
      Lake Ozark Mo
      http://www.webelectricproducts.com/products.htm
      There's the link I promise ya last night.
      Dec 2010
      Windy City, IL
      Quote Originally Posted by jbake View Post
      With LED's, you don't need "at least 3 tail lights", since LED's are small enough to be made into ROWS, on a Printed Circuit Board that can be sized to fit into your original taillight housings, and programmed for whatever sequential/non-sequential/flashing/stationary/etc. patterns you'd like, with the added benefit of not having to replace them for YEARS, unlike standard bulbs!
      '70 GS Stage 1 https://www.pro-touring.com/showthre...-1-project-car
      Restoration blog: http://1970buickgsstage1.blogspot.com/
      '70 GS 350 convertible
      '70 GS 350 hardtop
      '70 Skylark 4 dr post
      Jul 2009
      Grand Rapids, MI
      CALL Digi-Tails! That's the best thing to do.
      Will Ellis
      Build Thread
      Dec 2009
      I like that. Plug in some LED bulbs, put in a $70 sequential module and waa-la!
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Dec 2010
      Windy City, IL
      Converting my car to full LED (tailights/side markers/front markers/interior)!
      '70 GS 350 hardtop
      Cornettsville, ky
      why dont you try yourself. leds are pretty simple as for seqentail im not 100% on how to set that up but im sure you could find the info online
      Jun 2010
      Georgia
      I know how to set them up, and will end up going that route. The point to be made was that I found it odd that not only did no one return emails / contacts, but also that no one had a bolt in solution for the A-body Cutlass (without having to take one from a different car and hack it up).
      Boonville, Missouri
      Sparky - What year Cutlass?
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Jun 2010
      Georgia
      71 Cutlass S
      New Jersey
      Quote Originally Posted by SparkyRnD View Post
      With a typical interest of 25 inquires of a particular model, we usually pursue developing an LED tail light kit for the car in question. With the positive response to the GS/Skylark kit we recently made available we are quickly finding that the Buick and Olds market is indeed large and in need of many products that other manufactures simply overlook. Our marketing team is in discussion as to what Buick/Olds model is next for development. We are looking at all suggestions to better zone in on what Buick/Olds guys want to see out.
      Jun 2010
      Georgia
      Boonville, Missouri
      My advice is call Northwest Mustang / Classic LED's - Here are my thoughts. You can use (2) of his 1969 Chevelle boards per side and have them electrically tied together and route/shape them to fit inside your lens. If you use two boards you could do the sequential blinking like you desire. Talk to Larry about your application.
      By the way - I want the fronts. Check out www.globaloverdrive.com
      The lens shape and size is very close to that of the '69 Camaro. My LED's look great in those.
      Tony Edler
      Illumin8s
      New Jersey
      The car progress looks good! Within the next 4 weeks we will go ahead and work on initial prototypes for the 70 and 71 Cutlass body styles using our latest LED design technology.
      Dec 2011
      Ottawa
      I think the only difference between 1971 and 1972 Cutlass taillights is a different lense and a seperate reflector behind the lense for 1972. But I think the housings are the same shape. Maybe someone else can confirm this.
      I was thinking of making my own set for my car, but just haven't had the time to really study up and do it.
      Paul
      1972 Cutlass 2-door post, 455/th350 Project Thread
      1983 Delta 88, 307/200-4r, factory F-41 suspension
      2019 Mustang GT PP1
