Several cooling system questions...
OK, this year the cooling system in the Monte SS is going to get some attention to hopefully work out a few bugs and make it as efficient as possible. Last night I spent several hours reading through25 pages of past threads which answered some questions, but left me with others.
The next couple of days I am going to do some baseline testing. Armed with that information I'll be back looking for recommendations on corrective actions. In the meantime I have a few generic questions to ask opinions on.
For those that do not know let me preface by adding that the emissivity of a surface is its ability radiate heat. A perfect emitter is 1.0 and it drops from there.
My questions;
- Has anyone considered painting their aluminum radiator? Aluminum radiators have an emissivity of approximately .040 and the higher the level of polish the finish has the lower its level. Painting a radiator flat black or better yet wrinkle black can move its emissivity up towards .7-.8 making it a much better radiator.
- Does anyone know the affects of using De-Ionized water? I have 10's of thousands of gallons of DI water available. This water is ultra pure having resistance levels ~2Mohms and higher. We routinely place flood lights in the pools of this water to inspect the tanks and since the water is non-conductive there is no shock hazard. Would this eliminate any electrolysis? Also, there are no solids, chlorine or any other metals in the water.
- I currently have an Edelbrock hi-flow water pump installed. the upper port on the pump is plugged. Someone told me that I needed to unplug the port and route a hose from that port to a port on the intake manifold. This would aid in getting proper water flow and cooling to the rear of the heads. Can anyone confirm this?
Thanks for helping me get started on this.
1986 Monte SS, 427 sbc, Victor E manifold, FAST TB, FAST XFI, T56 6spd, Moser M9 rear 3:70, SC&C G5, Spohn lowers, Pole Position Uppers, Alston Coil Overs, Pirelli all around
