      Folsom, Ca
      Bleeding a custom power steering set up?
      A little background; 89 camaro with a V8. procharger powersteering bracket kit to mount a gm type 2 pump. I have a remote reservoir. It is about a 1 quart capacity. I believe the lines are 3/4 and 5/8 respectively to match the original size going in and out of my factory (but new-well, re-manufactured new from local auto parts store) iroc quick ratio gear box. When the vehicle is cold started the steering makes those grinding/squealing sounds when turning the wheel left to right. Once I get about a full lock both ways the sound goes away and my steering is flawless. Seems to only have this issue when the car sits a while like a fresh morning start. I have jacked the front wheels off the ground and cranked the wheel back and forth to bleed the system the best I can. Any recommendations to get rid of this annoying and embarrassing sound?
      Feb 2011
      South of Sydney, Australia
      Country Flag: Australia
      is it belt squeal or pump whine? for belt noise, check your belt tension, pulley alingment and for gunk buildup. try some dry lube or belt spray. for pump noise look in your fluid resivoir, is the fluid frothy? if so you have air in it. to blead jack front up and with car off turn steering from lock to lock 10 to 20 times. top up fluid and start car and repeat. check again when back on the ground. if pumps are not blead properly when first fitted they can become noisy and that is the end of them. I have seen new ones last 10 seconds. I hope ypurs is ok.
      " If it doesn't have a MOTOR, it's not a SPORT."
      Dajen.
      Houma, Louisiana
      A lot sometimes has to do with the design of the remote reservoir. I had the same problem and bled the system for hours and hours with same result. I called Tom Lee and he said, can you remove the top off of the reservoir with the engine running? My answer was no, he told me that was the problem with a lot of reservoirs, they were not properly baffled (which mine does not have) and the return line was not letting the fluid swirl upon returning to the reservoir. My return line was plumbed straight into the can, so I removed the No. 6 inlet fitting, drilled the end of it so I could tap it to a 1/8" pipe thread and installed a tee in the line. So now it swirls and no fluid spills out of the reservoir when I remove the cap while the engine is running. This worked for me.
      But perhaps yours is just the system is not fully bled, crank the car and let it run a few minutes without turning the wheels, shut it off and check the fluid, if it is foamy, let it set until it disappears and then start it up an run it for another minute or two, stop the engine and check for air in the fluid again. Do this 3 or 4 times without turning the wheels back and forth and then see if all the air is removed from the system. Hope this helps.
      Bill Haynie
      1970 Nova 572/620 TKO600
      2013 Boss 302 Laguna Seca
      Folsom, Ca
      Quote Originally Posted by kawaden View Post
      This is pump whine. and when it groans, the steering wheel is tough to turn but like i said, it only takes about one full lock to lock when I first start it to make the noise go away and have full power steering feel again. Fluid does not look frothy but it does look dirty. All my components are brand new however. I did the procedure for bleeding the system as you described and no good luck came of it.
      Quote Originally Posted by BayouSS View Post
      I am not understanding your directions on placing a tee in the line. Is this inside the resevoir? My return line goes in through the bottom of my remote resevoir and inside the resevoir their is a plastic tee that comes up about an inch from the bottom and allows fluid to pass back into the resevoir. my outlet is just a straight hole plumbed into the bottom.
      Houma, Louisiana
      The feed line to the pump from my reservoir is the same as yours, in the bottom of the tank. My return line though is in the side of the tank, the tee is inside the tank. The trouble I was having was when the fluid was returning to the reservoir it was flowing straight in and I believe the suction to the pump was pulling the air that was in the return line down into the inlet line causing the cavitation problem over and over and never letting the air bleed out of the system. With the tee inside the tank in the return line the fluid would swirl around the sides of the tank letting the air rise to the top and dissipate instead of being sucked back down to the pump suction.
      Did you do the bleeding with the wheels off the ground? If not jack up the front end and run the engine without turning the wheels, shut it off and check for foam/bubbles in the reservoir, do this 3 or 4 times and then turn the wheels full lock right them left and shut engine off and check for air in reservoir. This should work. BTW the feedline to the pump should be a minimum size of No. 10, return No. 6. If it still does it check the pump inlet hose for a restriction, reservoir height is above the pump correct?
      Bill Haynie
      Folsom, Ca
      Yes I have tried to bleed the system with the wheels off the ground, I must have cranked that wheel back and forth one hundred times. the feed and return lines are factory size. I believe 3/4 and 5/8 or -12 and -10.
      and reservoir is above the pump
