    Results 1 to 19 of 19
      Houston
      Hidden wiper motor
      I want to move the motor back two to four inches in my '71 Bird and would like to move the wiper motor inside the cowl. Anyone done this? I would like delay wipers and washers as well if that is not too much to ask. Thanks for your help.
      Wick
      '71 Camaro RS Project
      Merritt Island, FL
      Houston
      Is the 2nd Gen done the same way? It's a start.
      Wick
      Big Stone Gap, Virginia
      Wipers!!!
      I used the factory mounting bases on my car with an S-10 motor mounted on the inside. What a pain!! A trick setup I like better is used in street rods is made by Specialty Power Windows. Weld in 2 bungs and remote the motor anywhere, plus adjustable for any sweep you may need.
      Mark
      Houston
      www.specialtypowerwindows.com
      A little pricey but it saves some agrivation. Thanks
      Wick
      Melbourne, FL
      I hate to revive an old topic but I'm in the process of cleaning up my firewall. I'd like to relocate my wiper motor/washer pump. Besides spending $2-300 for a kit is there another way to remote mount the wiper motor on my 67 Firebird ??? My car is currently pretty well stripped so acces to most places on the car is not an issue.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Melbourne, FL
      Anything ???
      Feb 2004
      Paris, Illinois
      Quote Originally Posted by 67 455 Bird ragtop
      Anything ???
      This is what I did.
      I got the idea from Paul67 on here. It uses an '85 VW wiper motor. I wired mine up a little differently than he did. Here's how I wired it.
      I'm sure that it could have been a little cleaner, but since the VW wiper motor doesn't have a park circuit, I wanted to make sure it would stop at the bottom of the sweep.
      More pictures and even a failed idea of wiring are on my site at http://www.camaroheaven.org/modules....howpage&cid=36
      I haven't put a washer pump in the car yet, but I plan on doing it in the future. In testing the switch, it looks like when you push the factory '69 wiper switch, it grounds out so I am pretty sure that the ground for the washer pump would be driven off of it.
      Michael
      1969 Camaro
      CamaroHeaven.org
      fQuick Garage: http://www.fquick.com/Overkill
      Apr 2004
      Cedar Rapids, IA
      Really cheap idea is to just remove it and carry some rain X all the time.
      Melbourne, FL
      Quote Originally Posted by rohrt
      I've been considering doing just that. Since this will probably be a fair weather driven car probably won't see much rainy driving. Even here in Fla. Would probably even shave the cowl and clean it up where the wipers stick out. Haven't decided yet but leaning that way.
      Aug 2005
      Hamilton, NJ
      Here is the stock setup,, FYI.
      Hidden Wipers Tech.
      Scott from NJ.
      Vent Windows Forever! ...
      England
      I put a water tank in the trunk and run the orignal washer button on the 67 camaro wiper switch if that helps .
      paul67
      Apr 2002
      Every SUV I've owned, has had a cowl mounted wiper motor. The boxy 1990-200? Cherokees had one that was covered in a rubber sleeve for corrosion resistance. The current Envoy/Trailblazer has them too. I've been meaning to stop at the dealer parts counter and take a peak at one.
      --JMarsa
      Chicago
      shoot me an e-mail and i'll send you the scan's of the SPW install. I can also point you to the pics of the install we did in my truck.
      marty-mj
      Dublin, CA
      Bonzo,
      Thanks for posting the 2nd gen wiper link, I have been looking for some testing diagrams for awhile.
      Brent
      Nov 2004
      Sweden
      Country Flag: Sweden
      Hidden wiper motor.
      Hi!
      Here is what I did to hide the wiper motor.
      I have a -69 Camaro , but You get the idea.
      I haven´t finished the wiring job yet , but the wiper linkage seem to work very well.
      Parts from a -97 VW.
      I saw a similar way to mount the motor on a Pro-touring -67 Camaro , in a magazine. (CAR CRAFT Nov.issue 2004. Feature : Powder Up. )
      When You put on the fender , the motor will almost be invisible , but still reachable .
      If You still have the original brake master cylinder , You will have to remove the fender to maintain the motor.
      Good luck !
      "OSDMIKE"
      Melbourne, FL
      OSDMIKE - I have seen another person do the same with their 67/8. They just kept the motor as close as possible in the original positon and used a threaded rod to connect the motor linkage to the wiper transmission. I think he also relocated the water pump and resevoir to the trunk area. I'm leaning towards trying this method since my fenders are still off as well as my dash panel. So I have room to work on this mod. Thanks for the pics.
      Phoenix AZ
      Another option
      We used a wiper motor from a 88 Volvo, made a simple L bracket bolted inside the cowl works great, it looks too simple though...lol
      I will try and post some pics soon.
      Melbourne, FL
