      Sep 2007
      Denver
      forged crank damage?
      I'm resintalling a nearly new...maybe 20min idle run time....and noticed some sort of irregularity on the rear main journal. I can only feel one small area with my fingernail that's irregular otherwise is mostly a visual thing. I don't know if this was maybe a forging metallurgic irregularity or what. Mostly, just need some input as to whether this is anything to worry about. I included the lower bearing for reference...doesn't look too exciting to me.
      David Beckstrom DVM
      Mar 2011
      Ca
      i'd take that to a shop and see if it can be polished out, if not i'd have it turned, thats just me.
      Auburn, CA
      Could be just staining. Has this journal been repaired? If so this could be a weld failure.
      Tim Tracy
      Sep 2007
      Denver
      Brand new....20 min idle time only. I did run a metal edge lightly over it and all the lines seen could be felt.
      David Beckstrom DVM
      Jul 2008
      Ft. Worth, TX
      If it can be felt than it needs to be polished or turned. It will tear up the bearing in no time.
