      Nov 2010
      Novi Mi
      Bell crank design and thoughts.
      So I have decided to go with a pushrod, bell crank design, this helps with packaging.
      Reading some design threads on bell cranks is they talk about thrust bearings bring used in a interference or press fit into the crank. Can anyone tell me what a thrust bearing does?
      And would single shear work? Or would I be better to build clevis ends for the connections? I fear I will need spherical bushings for any misalignment that might happen a the suspension cycles.
