      Nebraska
      Rear suspension help!
      I need some help here guys! I’ve got a 10 bolt with multi-leaf spring perches and a set of DSE 3” drop. I’m also running a mono-leaf shock plate with the dual eyelets and Bilstein shocks. The issue I’m having is that lower shock mount is about ¼” from my rim and there are signs of rubbing. My question is if I change over to a multi-leaf shock plate and shocks will this fix my problem?
      Click image for larger version.
      Craig
      69 Camaro RS 327
      69 Camaro Custom twin turbo
      70 Bonneville 455 Convert "the boat"
      71 PT Camaro
      san diego
      Can you add a wheel spacer, maybe 1/4".
      Jun 2009
      Central FL
      Quote Originally Posted by Bryce View Post
      This. Just shim it out slightly.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Mar 2012
      Texas
      Buy the multi-leaf plates there is an 1 or so difference in the mounting point for the shock. I converted from single to multi and had the same issue. Heartbeat city has the plates, seems like they were around 90-100$
      That will fix your problem, good luck and nice car!
