    Results 1 to 3 of 3
      Charlotte, North Carolina
      69 Camaro with LS1 Calipers Brake hose Connection Questions
      How do I hook up the late model brake hose (metric) from the LS1 calipers to the stock 1969 Camaro brake lines...do they make an adapter? Please advise and let me know where I can purchase. Thanks in advance for input!
      Dec 2002
      Lost Wages, Nevada
      You can purchase the 'frame' connecton that adapts the hard line to an AN.... from Earls, Aeroquip and Goodrich.
      DUBUQUE IA
      if you can make bubble flairs (if that is what thay need)just cut the fittings off a short cheep peice of metric line and use the fitting. the tubing is the same size. if thay take a typical flair do the same thing. should be real easy
