      May 2010
      New Zealand
      Country Flag: New Zealand
      A Body Body Mounts
      I'm going to go with poly, except I cant find a kit stateside that includes the steel inserts/bolts.
      Do you guys buy them or make up a kit?
      Chris
      68 El Camino - Street Track Drag - in progress..
      Toyota Station Wagon - only thing that actually runs....
      Loganville, GA
      One option if you can't find the inserts and bolts, is to buy the original rubber style and get the hardware you need from that kit and use it with the poly mounts. But that cost more $$$$, which is why my El Camino had rubber body bushings, didn't want to buy two kits.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      RI
      I dont run the inner sleeve just a grade 8 bolt and washer, the rubber mount hardware is different. I believe I'll be fine with my mounts like this.
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      http://www.youtube.com/watch?v=SER1gBLn2N0
      Dec 2008
      Detroit
      I was looking at Prothane body bushings for my Cutlass and noticed all the ones for 68-72 did not come with inserts, 65-67 do. I wonder why?
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      May 2010
      New Zealand
      Quote Originally Posted by csouth View Post
      Yeah that's what I noticed and couldnt figure it out either.
      Maybe the density of the poly is deemed enough to not need the crush tube, but still doesnt explain why the earlier stuff has them.
      Hmm
      Chris
      Dec 2008
      Detroit
      Quote Originally Posted by Simmo View Post
      Hmm
      Thats a thought. Maybe the mounting points changed some between the years and they were not deemes necessary?
      Chris--
      Dec 2011
      Alabama
      A Body Body Mounts
      OPG carries the hardware that contains the sleeves. Got mine a while back.
