    Page 2 of 2 FirstFirst 1 2
    Results 21 to 36 of 36
    1. #21
      Feb 2007
      Tha' South
      Quote Originally Posted by 69importkilla View Post
      So just got the pump in and wired, quite as hell. Didnt even realize it was on at first. +1 for the new Holley Hp pumps..
      What is the part number of the one you got??
      73 Camaro LQ9, BW S480 Turbo, Jake's STG 3 4L80E, E85.
    2. #22
      North Carolina
      It was an HP125 Model, Holley # 12-125
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
    3. #23
      Jan 2011
      Boston, MA
      I have a Holley Black and it's annoyingly loud, even with sound deadener, a carpeted trunk and carpeted trunk divider.
      Interested in the HP pump as well.
    4. #24
      Walton, NY
      Quote Originally Posted by 67 455 Bird ragtop View Post
      Besides the Holley any other suggestions for an in-tank carb fuel pump ??
      I'm interested as well. I have a Walbro 255 for when I convert to EFI, but doubt it could be regulated down to carb pressure. Would like to ditch my current Carter mech in favor of an in-tank elec.
    5. #25
      Melbourne, FL
      Quote Originally Posted by woody80z28 View Post
      Actually that's what I found a lot of guys are using. Use a good quality return style regulator and your golden. According to folks who use that pump.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
    6. #26
      Walton, NY
      Really....that would be sweet! I could actually try that with the pump out of the car. Submerge it in fuel and hook it to the feed line, set the regulator at the pressure I want and see if I get creep. With the engine not running (consuming zero fuel) it would let me know if the return could keep up with the full supply flow of the pump.
      Now would be the perfect time to the test since my tank is currently out of the car and I have easy access to the feed/return lines by the leaf spring. My regulator is a cheap Holley deadhead that is converted to return style (so the feed is totally unrestricted and the return should have a full 3/8 pipe to take advantage of if needed.) Maybe that would be enough?
    7. #27
      Melbourne, FL
      Keep in mind. Rule of thumb for return line is one size bigger than the supply line.
    8. #28
      May 2012
      Inman SC
      are you running a return line/ regulator with this?
      I'm about ready to order.....thanks
      73 camaro 355 EZ EFI, 700R4, Vintage Air.....15mpg with the a/c on
    9. #29
      North Carolina
      No return line or regulator...
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
    10. #30
      Aug 2009
      If.you have ANY ethanol in your gas stay miles away from Holley pumps unless you buy one for alcohol....I used pump gas ,, straight up 91 octane here in Michigan and.it.corroded the Hell outa my Holley blue after a five min test run and then sitting one.winter.
    11. #31
      North Carolina
      Yeah Holley Blue pumps are ancient technology. The new HP pumps are built much different...
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
    12. #32
      May 2010
      Long Island, NY
      ^^^Agreed, I run an hp150 (pn#12-150) from holley. It's so quiet i occasionally forget to turn it on, and 2 minutes down the road the car stall's out. Have had it over a year, and no problems what so ever. It's also a continuous duty pump, so its perfect for a cruiser. Im running the quick fuel 30-803 regulator, -10 out of the cell to an aeromotive filter directly into the pump, then -8 to the regulator and -6 to each bowl.
    13. #33
      Jan 2011
      Boston, MA
      For those running the Holley HP pumps, are you still happy with them a few months later? I'm going to toss my Holley Black pump at the end of the season and will most likely go with the HP125 or 150.
    14. #34
      North Carolina
      yep, its still running quite well...no issues at all.
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
    15. #35
      Jan 2011
      Boston, MA
      Thanks, thats good to hear. Mine still sounds like a swarm of angry bees stuck in a beer can.
    16. #36
      Aug 2012
      Warsaw mo
      i use only aeromotive pumps.never had any trouble with them.i have a a1000 with a bypass for my car.
      72' monte . Factory number matching 454.
