Thread: TCP G-Link vs Ridetech AirBar
02-29-2012 #1
I am looking for the TCP G-bar or link with the pivot ball type, But with another set of shocks? I need the SELECT coilover ones from ridetech, the new types with the electric button to select hard/soft setting. I also need them for the front.
http://www.ridetech.com/store/64-66-...ct-series.html
http://www.ridetech.com/store/1964-1966-ford-mustang-coilover-front-system-select.html
The reason for me is that I like to keep the car a little bit street friendly and stiff on demand (highway, nice tarmac and track).
I think that the air suspension will hurt the performance a bit. Right now I have Qa1 coils front and Qa1 shocks with 5 leaf springs rear. excellent steering manners, razor sharp, but want to get rid of the springs for a little more room.
Does anyone has experience with these already?
I have a 65 mustang fastback and use it on street, strip and autocross. it is caged, 700+ HP, manual, 335-30-18 rear tires + @ front a CCP susp. brace with tubular arms.
what do you suggest as a spring rate?
any other suggestions like a splined bar.
I tried to contact Brett from Ridetech, and Chris from TCP, but no reaction so far.
If you know or are a dealer who can help me, please let me know.
Thanks!!
02-29-2012 #2How have you tried to contact me? I've had no calls or emails from you that I know of. My direct email is [email protected]. I don't do PM's because I don't keep up with this forum every day, and my emals come directly to my phone.
Email me direct and I can answer anything you need...or get you to someone who can. Thanks!Bret Voelkel
Founder/ Former Owner
How do you spell Impossible?
02-29-2012 #3Out of curiosity...why do you think the air suspension would hurt the performance?
I'm not challenging your opinion...just examining the perception so I can explain the different systems.Bret Voelkel
02-29-2012 #4Hi Bret,
I used the email function on this forum (click on the name and choose sent an email), so that might be the problem.
At first I was considering the air setup, but I couldn't find good info on performance. In my opinion, when you adjust the height, it will affect the handling. I also don not understand if the ride quality if different in the different heights. Will a low height be as stiff in handling as a high height? It seems that more pressure makes it stiffer, so a low ride is not performance plus on air i guess. And what about the pinion angle? it will change when adjusting the height i guess?
As for the coil overs, i see them on most road racing cars, plus they are less expensive and failure safer. (less parts that can fail).
Why I prefer the G-Link, the possibilities of adjusting and the points the shocks are mount looking stronger and might clear the exhaust (3" )
The email is on its way!!
03-17-2012 #5anyone experience with the air vs coil over setup?
Pros - cons with road racing / autocross?
03-21-2012 #6
