    Results 1 to 12 of 12
      Feb 2010
      Central NJ
      NOISY T-56... please help!
      I Just finished intalling my t-56 (behind a SBC) and I noticed a noise coming from the trans... The noise is only after the car has moved in first gear (ex: pulling out of my garage) then I press on the clutch pedal and I'll hear a sound almost like a rattle combined with a spinning noise from inside the trans (from the front). It almost sounds like something is still spinning in the trans when the car comes to a stop and the clutch is pressed in. I have a SBC with t56 adaptor plate/mech linkage/Lakewood bell (aligned)/ extended pilot bearing (req with adaptor plate)/Castrol Dextron 3 fluid 3.75 quarts (req) and a brand new McCleod Clutch/TO bearing... the trans is from an 05 GTO.
      The trans shifts great in ALL gears, but when I come to a stop (in first or second) the sound occurs. Here is what I've noticed: It seems to do this after the trans is warm (fluid gets thinner)... the noise can be altered (sometimes stopped) by pressing/releasing the clutch pedal or shifting into neutal. I've also noticed that under very very light braking the sound is almost non existing. The trans is used, but I know the seller and he says it never made this noise (he is a good friend, so i trust him).
      I've had the car on the highway, around town and under quite a few 60-75% blasts, the trans doesn't make a sound or rattle....
      I'm sure this is not normal, but the trans works too good and shifts too nice under any other circumstances to think there was a major issue...
      Any Ideas on the cause of this sound????
      Thanks in Advance!
      -Sean
      How was the preload on the input shaft before you installed it? Do you recall if the input shaft had any lateral movement before you installed the transmission?
      GeoffP
      68 Camaro - LS1/T-56
      Feb 2010
      Central NJ
      No, it didnt have any movement I could observe by using my hand or looking with my eye... I did not measure it exactly though. It did come out of a friends car working just fine (trans has aprox. 20,000 miles)
      Thanks- Sean
      BTW- Big thanks to Tom Farrington at Tom Farrington's Tech Line for listening to my issue and offering sugestions..hahahaha
      Feb 2010
      Central NJ
      I've read issues with the input shaft bearing or bell alignment, but I really dialed the bell in and double checked everything... nothing rattles or shakes under acceleration or under any other cricumstance (than as stated above)
      I've read about rough idling cams causing issues (I have a 501 lift cam), but this is not when the car is in nuetral at idle or even that consistant... ONLY after the car has moved with the clutch pedal pressed... almost like its still spinnig after the car is stopped and the clutch is disengaged...after about 10 seconds or moving it to neutral the sound goes away or gets very faint (see OP)
      -Sean
      The only obvious thing I can think of is that the throwout bearing has come loose from the slave cylinder possibly during the tranny installation. Not knowing the condition of the bearing assembly or how common it is for the LS style throwout bearing assembly to come apart from the slave cylinder, this is only a guess. My thought process is that if the bearing is loose that it's rattling when the clutch is released, very similar to the old mechanical style GM and Ford clutches (they rattled if the throwout bearing wasn't securely hooked to the clutch fork). I'd also guess the input shaft is fine based on what you said. I hope this helps in some small way.
      GeoffP
      Feb 2010
      Central NJ
      Quote Originally Posted by GeoffP View Post
      Thanks Geoff... Its funny you should mention the "old" mechanical GM stuff because thats what I'm using.... My adaptor plate allowed me to run the entire original (mech) setup from my super t-10 trans. I just never had any noises or rattles from the t-10 like this. I started to think it was an input shaft issue, but Im sure it would be a noise that occured much more often... if not all the time (I had a mustang t-5 that not only rattled and whined but made noises in every gear). Thanks again for the input Geoff
      -Sean
      Auburn, CA
      Is it possible you are over extending the throw out bearing? My T56 did that when my throw out bearing was over lifting.
      Tim Tracy
      Feb 2010
      Central NJ
      Quote Originally Posted by TT302Z28 View Post
      Thanks for the info Tim, I'm not sure if its over extending or how I can tell? All I know is the new clutch is adjusted just like I had it for the t-10.... the car gets rolling when the clutch pedal is about 1.5-2 inches off the floor ( not too high/not too low). I could try shortening the adjustment rod and having the clutch grab lower, but I think if it was over extending, the clutch would be grabing much higher, since the adjutment rod would be at a longer length.
      Did you have similar sound and how did you correct the issue?
      Sean
      I just re-read your original post...it makes noise with the clutch depressed not when released, right? I thought it was making noise when released (which is more common). I had typed the suggestion below before reading it again - maybe it will help but probably not if the rattle happens when the clutch is pressed in.
      It's the mechanical linkage and it rattles with the clutch out - try putting a preload spring on the clutch fork. A preload spring will hold the throwout bearing against the pressure plate fingers with just enough tension to keep it from rattling.
      GeoffP
      Auburn, CA
      Sean:
      Try pushing in the clutch about an inch past release and see if it does it then. If so this is likely a pilot bearing or the input shaft bearing.
      If not it is the throw out bearing either bad or over throwing.
      Tim Tracy
      Austin, TX
      Are you using a GM or Lakewood clutch fork? I had lots of issues with my Lakewood fork binding the throwout bearing. You can google it and find the details.
      Feb 2010
      Central NJ
      Thanks for all the tips guys.... I'm starting to think this is fluid related... If it were linkage or mechanical related (aside from intern trans parts) I think the noise would be all the time.... the reason why i'm thinking fluid is because it seems to only occur after the trans is warmed up or has been driving (then coming to a stop). Ex: this morning I drove the car around the block a few times (still cold).. it didnt make any noise or rattle a bit... (had to park it shortly after, since I had to go to a family function)
      If it were an input shaft/pilot or linkage issue wouldn't the noise be right from start up and more consistant in each gear??? whine,rattle,shake, whirll???
      tt302z28: I'm going to shorten the linkage rod just a tiny bit and see if the PP is in fact getting over thrown.. I doubt it since the T/O is the shortest GM makes and the clutch is grabing at a really good height.
      sgernon: I am using a lakewood clutch fork, but it doesnt appear to be hanging up on anything (i even checked movement before I installed the trans...
      I'm kind of baffled. But to me, the noise is like the trans is still spinning after a stop and the clutch is pressed in... (after the trans is "warm")... maybe more of a gear rollover noise, than a loose rattle...
      Thanks again guys-
      Sean
