      Apr 2010
      Montebello, CA
      Centerforce SBC to T56 Conversion Flywheel
      Flywheel to convert SBC 350two piece rear main to accomodate Lt-1 T56
      will throw in flywheel bolts as well. just needs a resurface.
      asking 300 shipped
      Jun 2010
      Deployed
      May I ask what makes this flywheel different than the reguar SBC? IS this required for Hydraulic pressure plate?
      1970 Camaro/DSE build
      Sep 2011
      Eagle, MI
      If I understand your question right, this flywheel is needed because the flywheel bolt holes on a two piece rear main seal block are further apart than on a one piece pear main seal. the hole in the crank for the flywheel on a one piece RMS are basically flush with the back of the block while the holes on a two piece RMS crank stick out. This creates an offset which needs to be compensated for. another reason for the special flywheel. Hopefully I touched on your question.
      I had the same question when i was going to mount an lt1 to my sbc 327 but i changed directions.
      But good luck with sale. Should sell quick!
      Apr 2010
      Montebello, CA
      Sold
