Results 1 to 1 of 1
02-20-2012 #1
- Jul 2005
- Houston
- 93
69 Camaro Musclebar question/concers
I know there is another thread that touches on this paticular concern (see below) but is it still the case that you have to cut off the bump stops on a stock subframe to make the musclebar fit? I wish I had know this prior to buying the bar. Stock subframe is still a somewhat common application and ridetech should clearly state that cutting up your subframe may be required. Does anyone have any tips for going about cutting off the bump stops?
Thanks.
Originally Posted by Bad94
is any one running this sway bar with a sub frame that has the bump stop bracket on the front side of the coil spring pocket?
Yes, I just installed one on a 69 Camaro with a stock subframe and Strong Arm control arms. I had to cut off the upper bumpstop brackets to clear thesway bar side arms through full suspension travel. Not a huge deal, and the rest of the install was very straight forward
