      Sep 2011
      Explorer rear in 64 Falcon
      Greetings,
      I finally got a complete 8.8 with disks. I need it cut down and the brackets (from the TCI triangulated 4 link) welded on so I can get her rolling again. Any suggestions in the SoCal area (LA to Oxnard)!
      thx guys!
      Texan Back in Texas!
      No suggestions however I did the exact same thing for my Falcon (should have it bolted up under the car this weekend.) Make sure they get all the measurements spot on when they do the welding.
      1965 Falcon Hardtop
      Sep 2011
      Quote Originally Posted by LowFast View Post
      I've been watching your build, and our builds are very similar. I hit you up with an email asking about the mini-tub and moving your coils in, did you have any problems...it looks like you want all out and re did the entire back half. What should I be concerned with when taking the brackets in to get them welded....I've got the instructions and measurements handy, was wondering if you had any issues.
      BTW It looks like you did move them in about 4-5", what the lower control arms? Did you move them inbound of the frame as well? Was this a cascading effect on the rest of the suspension?
      Well, mine ended up being all custom, had to cut up the cradle and redo all of the mounting points to accomodate the wide tires. Forced me to go to a splined rear swaybar instead of the bent unit from TCI. I had to measure about 6 times, tack it, and then remeasure once more, including bolting it all up to make sure it worked. Then I took it all back appart to fully weld all the mounts. One word of caution, the weld on axle brakets holes are not large enough for the 8.8, so I had to basically hog them out to make them slide over the axle. If you are going with the stock width set-up with stock framerails just follow the TCI measurements and you should be good to go. When you have the explorer rear narrowed make sure they center the pinion, the stock unit is offset by a few inches and you will run into clearance problems underneath if you do not have it centered as part of the narrowing of the overall width.
      1965 Falcon Hardtop
      san diego
      I would go back to TCI or head over to currie. Both might have the jigs to weld this up.
      Sep 2011
      Quote Originally Posted by Bryce View Post
      Currie said they weren't interested(?) not sure why, the wife is calling back today...I'm still deployed.
      LowFast I decided to tuck as much under her as I could without cutting...money is will become an issue if not...the body/paint need some love too.
      Bryce...How wide is your rear....flange to flange, you've got a decent tire under her! Any offset and wheel width advice you have---I'm all ears!
      Thx guys!
      san diego
      Mine is the stock width, 57.5" axle flange to axle flange.
      I have a 17x9.5 with 6.5 backspace wheel and a 275/40/17 tire. I rub just a little on hard cornering. But I have a 3-link with watts.
      Most cost effective would be to only shorten the long side to match the short side and then buy a second short axle, in fact I still have my stock axles and would be willing to make you a killer deal on the short one if you want it. Then buy your wheels with the correct backspace to match the axle width. This means you only pay to cut and weld one side and you get to aviod the $350+ custom axles.
      1965 Falcon Hardtop
