    Page 9 of 10 FirstFirst ... 4 5 6 7 8 9 10 LastLast
    Results 161 to 180 of 182
    1. #161
      Feb 2012
      SW, Michigan
      It's a good day for a update!!
    2. #162
      Under Lake Michigan
      Awesome fab work! I'm enjoying the build.
      15 Camaro 2SS 1LE summer ride
      00 Yukon work ride - parts hauler
      69 Camaro LS Turbo - project car
    3. #163
      Oct 2014
      Vancouver, Wa
      Love it. keep up the good work.
    4. #164
      Feb 2012
      SW, Michigan
      Thanks guys.. I'll try to keep pictures coming as long as we progress.
    5. #165
      Feb 2012
      SW, Michigan
      I haven't posted anything on this forum in a while, but I decided to make a retro looking engine cover for the LS1.
      I still have a bit to do but it's starting to take shape.
    6. #166
      Aug 2008
      jacksonville,fl
      Cover should look cool. Can't particularly say I've seen a dual quad style cover on an LS1 ;;;;;;;YET. Always good to be different.
    7. #167
      Feb 2012
      SW, Michigan
      That was kinda the idea,, make it a little different and give it a little bit of a retro flair.. Glad it worked out, I had a lot of time into making that thing.
    8. #168
      Dec 2010
      Charlestown NH
      Your exhaust hanger design is fantastic. It's so hard to find a good hanger set up, you literally have to be inventive
      https://www.pro-touring.com/showthre...-Touring-Truck
      DMP Fabrication LLC
      Follow me on Instagram for welding and truck progress! - Americangraffiti
    9. #169
      Feb 2012
      SW, Michigan
      Roll pan is about wrapped up!!!
    10. #170
      Nov 2011
      Nice! I like fab work with new twists on the necessary items.
      Greg
    11. #171
      LI,NY
      Great work guys! Really enjoy the pics and your work......
      65 Vista Cruiser
      67 Delta 88 Vert
      70 Vista Cruiser Pro-Tour Project
      96 T-Bird
      69 BSA A65L
      48 Ford F5
      https://www.pro-touring.com/showthre...o-Tour-Project
    12. #172
      Feb 2012
      SW, Michigan
      Thanks guys, and sometimes it's those necessary items that can stump you. Especially when they don't work with your original plan. However I like this better anyways.
    13. #173
      Jan 2009
      Love the roll pan bumper combo
    14. #174
      Feb 2012
      SW, Michigan
      Made some changes to the engine compartment.
    15. #175
      May 2015
      Iowa
      What front cross member and suspension is that under your truck
    16. #176
      Feb 2012
      SW, Michigan
      Quote Originally Posted by Bentbolt View Post
      I know I already answered but it's Thorbecke brothers in case anybody else wanted to know..
      Which as far as i know, they are not making them right now.
    17. #177
      Feb 2012
      SW, Michigan
      Custom tail lights and mounting stems.
    18. #178
      Feb 2012
      SW, Michigan
      Making more progress in the engine compartment as well.
    19. #179
      Jan 2015
      Mountains of AZ
      Are you still running the filter into the cab with that new setup? Why the change from the original inner fender setup you fabbed?
      My finished daily
      1966 Fairlane
      306 with 4R70W
      QA1 Coilovers,vintage air,
      Current project
      1948 Ford F1
      Lexus SC400 IFS
      DOHC 4.6 with 4R70w
    20. #180
      Feb 2012
      SW, Michigan
      Quote Originally Posted by c91x View Post
      Yes we are still running the ram air hood set-up.
      And there were just a lot of things I didn't like about the original set-up, if I had made it all bolt on it would have been a lot nicer, but it was welded to the firewall which when the tubing was welded to the firewall we had more warpage than I was happy with, So I wasn't happy with that, and I wasn't happy with the radiator support either, so I started over, new firewall, made a radiator support from scratch to a design I am much happier with. I originally wanted to use aircraft rivets to hold the inner panels to the original bars, this made it hard to work on anything in the engine compartment without taking the cab off, which made me realize it would make it hard for the owner to work on. Especially after fresh paint, It was harder to get things to line up properly because the radiator support was welded to the structure, left little room for adjustments. I wasn't happy with the hood hinge set-up, also have a new plan for that, just need to get some pieces machined before I can begin that part of the project. We are also now going for a cleaner look, the original wasn't bad but with everything going with a cleaner/classier feel the first design didn't fit as well, that had more of a aggressive look. However if I had made it all bolt in I don't think I would have started over, but with everything I was unhappy with this just became the best solution.. I'm not necessarily happy with having to re-do everything but in the end it will be worth it over all. I think part of the issue is that over the course of the 4 years this truck has been here our fabrication work has evolved a lot and I just wanted to bring this up to where we want to be with everything. Luckily once this is finished I can continue as planned.
