    Results 1 to 15 of 15
      May 2002
      Southeastern WI
      FS 1967 Camaro Pro Touring G Machine
      Absolutely no expense has been spared in building this high quality Pro Touring car that features excellent acceleration, handling, stopping, refined road manners, and great looks to match. The end product is an outstanding street car that is also very capable on the track.
      The car was originally equipped with a 6 cylinder and a Powerglide, so no rare muscle cars were harmed in this build.
      The list below highlights the parts that have gone into the build.
      Engine
      Wegner Motorsports L92 (6.2L) balanced and blueprinted Wegner CNC cylinder heads 10.87:1 compression,
      Comp Cams hydraulic roller cam (.585/.595 lift, 291/301 duration)
      LS7 lifters, Comp Cams 3/8” Magnum pushrods
      Precision Metalcraft fabricated aluminum intake, FAST 92mm TB, 42 lb injectors
      Pantera EFI ECU882C ECM
      Champ pans baffled 5 ½ quart road race oil pan
      Stewart water pump
      ATI Super Damper
      Griffin aluminum radiator
      Wegner billet CNC valve covers
      Hooker Headers Ceramic coated
      Custom fabricated Stainless 3” exhaust with Magnaflow mufflers
      Wegner billet accessory drive system
      599HP at 6800 rpm 505 lb/ft torque at 5600 rpm at flywheel
      Ricks Stainless narrowed gas tank with Walbro 255 gph fuel pump
      optima red top battery mounted in trunk
      Engine compartment wiring painstakingly routed to be as hidden as possible
      Transmission
      Tremec T56 6 speed built by Liberty’s Gears
      Spec Stage 3 clutch and pressure plate
      ATS transmission cross member
      Pro 5.0 shifter, Twist Machine billet lever
      Custom Strange Chrome-moly driveshaft
      Aluminum 2 piece driveshaft loop
      Ford 9 inch rear end with Strange center section and 4:10 gears
      Front Suspension
      DSE tubular A-arms upper and lower
      DSE coil over conversion
      Koni coil over shocks with Afco 550 lb springs
      DSE 1 1/8” hollow anti roll bar
      Baer 6S six piston brakes with 14” 2 piece rotors
      Rear Suspension
      DSE Minitubs
      ridetech 4 link rear suspension
      QA1 coil over shocks with 275 lb springs
      Fully welded sub frame connectors
      PBR (Baer) with 13” 2 piece rotors
      Wheels / Tires
      Kinesis K18R three piece forged wheels (18x8 front, 18x11 rear)
      Falken Azenis tires (245/40ZR18 front, 315/30ZR18 rear)
      ARP long wheel studs
      Interior
      Recaro Pole Position seats
      G Force 5 point cam lock harnesses
      Autometer Sport Comp gauges
      Vintage Air Gen II Compac A/C and heat
      6 point roll cage
      DSE select a speed wiper motor
      Exterior
      BASF Diamont Base/Clear -Victory Red
      Glasstek Carbon Fiber 2” cowl induction hood
      Ring Brothers Billet “airframe” hood hinges
      Marquez billet taillights with American Autowire LEDs.
      Twist Machine Aluminum rear spoiler
      Stock Camaro spoiler also goes with car and is painted to match
      Stainless fastener kit from Prodigy Customs used on assembly
      Front bumper bracket slots in fenders were eliminated. Firewall smoothed. Emblems, drip rail trim, wheel opening moldings, rocker trim and antenna hole were all eliminated and holes welded up. Trunk floor and fuel tank were modified to move the filler behind the rear license plate (like a 69 Camaro).
      Car was media blasted to bare metal in 2008 and was found to be extremely solid. Full quarter panels had been installed by prior owner and by all appearances were professionally installed. The front fenders each received small (4”x4”) patch panels in the rear corners. There was no other rust found on the car.
      It was painted in winter 2008-2009 in BASF Victory Red base/clear with a satin black bumblebee stripe on the nose. Wing window frames were re chromed as well as the rear bumper. All rubber seals are new. Glass is in great shape as is all stainless window trim.
      The car works great whether you are carving up the twisty bits or cruising down the interstate. The double overdrive T56 transmission helps it deliver 20+ mpg on the highway. So much has gone into this project that it would be impossible to list it all. Please email with any specific questions you may have.
      Camaro Performers Magazine feature car October 2010
      (please note: rear suspension, rear end and exhaust have been upgraded since the article was written)
      http://www.camaroperformers.com/feat...o/viewall.html
      I will consider any of the following plus cash as trades. C5 or C6 Z06, LS powered 4th gen F Body, 5th gen Camaro SS, 04-06 GTO, CTS-V, BMW M3, Porsche 911, 20-28 foot enclosed trailer, Duramax powered truck, late model Mustang Boss 302 or GT500, or anything else that is interesting. No boats, ATVs or sport bikes.
      $69,000
      Jeff
