    Thread: DBC Ls1
      May 2011
      DBC Ls1
      Im looking for a pedal to use for a drive by cable ls1 swap what did you guys use that worked. I did a bunch of looking and this is what i found someone else used. http://www.restorationperformance.co...r-Pedal/Detail wil this work or do i have any other options? Thanks.
      Beach Park IL
      You can use your stock camaro pedal with a LS1 throttle cable from lokar and a little creativity. After that Billet Specialties and Lokar both make bolt in pedals that will work with the previously mentioned cable.
      Pensacola, FL
      I used the lokar pedal & really like it. The adjustablilty of the pedal height sold me on it. I've the seen the factory 6cyl cable operated pedal in 1st gen camaros being used, but not sure which cable would work with it.
