    Thread: New Compressor
      Houston Texas
      New Compressor
      Pressure switch went out on my crapsman compressor and didn't want to risk an explosion to work on my car so i went out and upgraded a bit to a new compressor. Havent posted any of my new stuff in a while so i thought i'd just show you all. Need a few more fittings to be able to use it but it sounds good! haha
      68 Camaro - never to be finished
      06 Silverado - Forged 370, L92 Heads, big cam, 4l80e ect. eventual donor for the above
      http://www.youtube.com/watch?v=KmB2y7uX38I
      Macon, Ga.
      What exhaust system you running on the compressor-lol
      Bill
      Trailers are for BOATS!
      Jul 2002
      Mesquite, TX
      Beefy.
      What are the specs on it and what did you have to pay (if you don't mind me asking?)
      Houston Texas
      80 gallon 2 stage 7 hp motor 12.6 scfm 175 max PSI
      I ended up paying a little over a thousand with water trap, oil, fittings, wiring, tax, and a few other things. Still missing 1 fitting so i couldnt use it tonight but 7 AM tomorrow i should be able to when home depot opens.
      Here is the link to it: http://www.homedepot.com/prel80/HDUS...cm_pla=1319015
      the next compressor down only went up to 135 psi, 60 gallon tank, single stage compressor, half the scfm for $450
      and the compressor up from it was the same psi, same tank, but it had a different compressor and it was $1700
      Houston Texas
      Update: if anyone is looking for a good compressor i would def. recomend this one if your looking for something that wont break the bank to much. It seems like i can run the plasma cutter forever with it haha
