    Results 1 to 20 of 22
      Dec 2009
      Brunswick, GA
      Ridetech Outer Tierod Stud Clearance Problem
      It's me again with another ridetech question. Has anybody used the truturn suspension kit on American Racing Torque Thrust II 17x9.5 wheels. I finally got my wilwood brakes on today (had to turn the seal backwards for it to seal...long story for those who havn't read). Finally, felt like I had made progress and when to bolt the wheel up to the hubs and when tightening down the wheel, noticed it wasn't turning. I figured something was wrong (it always is...) and I noticed that the threads on the bottom of the outer tierod end studd had dug into the inside of the wheel (hence the reason it wouldn't turn). I can post pics later on. I know the truturn suspension kit was supposed to work with 17's. Has anybody else had this same problem. Also, I noticed that the stud has a cotter pin hole in it. Do you still need to put the cotter pin in even though it's not a castle nut on the bottom? Just trying to figure out if I can cut some off the bottom of the end of the studd to get the clearance I need. If the studd was shorter it would fit with no problem. Thanks guys
      1967 Camaro RS/SS - Project "Skunkworks" in Progress...
      Dec 2009
      Brunswick, GA
      May have solved my problem. The ridetech steering arms that connect to the spindle, do the ends of the steering arm angle outward away from the car or inward toward the motor? On their directions, they have it pictured angling outwards. However, watching their videos they have it angled inward towards the motor I believe. I'm sure this would gain some clearance. Thanks guys
      Central CA USA
      I think they should point inward towards the engine. Maybe this photo will help:
      Dec 2009
      Brunswick, GA
      Just wanted to give you an update. If you install the truturn system, the steering arms need to angle inwards towards the motor, not outwards like the directions show. If I ever get finish with everything, I'll post pics and write up directions on how to install their coilover kit and tru turn.
      Cincinnati Ohio
      I have to sit back and laugh at everyone of your post about this kit. I was one of the first to buy this kit and install it and put the car on the track too. And i did the complete kit along with switching coilover in about 4 hours. How are you have so many problem?
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Indiana
      I looked at the instructions again just now. The illustration you are referring to is a generic representation of the components and how they relate to one another. You are correct...the illustration does have an ever so slight curve to the outside. I didn't notice it because actually, I wasn't aware you could even get the arms to bolt up the wrong way. An actual picture would have been clearer. Sorry for the confusion. I'll get it fixed!
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Dec 2009
      Brunswick, GA
      Quote Originally Posted by Bad94 View Post
      As I was told, these kits are generic and sometimes don't fit specific applications without modifying. This is due to the factory variances and that is "Hod Rodding." I got sent the wrong coilover spring in the kit for the rear (which ridetech exchanged with no problem) which was a time set back. I then redrilled all the ball joint holes in the upper control arms so that they would line up. Then I waited over 3 months for my Moser 12 bolt I ordered (even though they supposedly have a 2 day turn around). It took around 14 weeks to get wheels and tires from American Racing. Wilwood brakes do not seal on the back side of the hub on ridetech spindles. Either have to go with a different seal (look that crap up in thousandeths of inches to get it to work) or turn the seal backwards which I didn't want to do initially because I was worried about it sealing (I figured there was a reason wilwood said install it a specific way). Ridetech really helped me out get through the brake senario. Then I installed the steering arms just like the picture showed and they hit the inside of the wheel. The only other thing I would like to see ridetech add to their instructions is that on their newer bar systems for the rear, the long arm is off set now and not centered like their pictures show. The installer needs to know which side to put the off set too. I was hoping to get my car rolling before baseball season but that didn't happen.
      May 2002
      Northern California
      because you toss the instructions out like the average grease monkey. oh and
      for laughing at these guys for actually trying to do it themselves. LOL
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Beach Park IL
      ahhh, memes gotta love em. I am eating breakfast and almost did a cereal guy when I saw that.
      I dont think bad94 was laughing at him for trying to do it himself......it's that every time there is an issue its a new thread.
      The last thing I do is post a thread on a public forum. ridetech is pretty good about putting their phone number on stuff and the op already stated that they have helped him numerous times already.
      Feb 2011
      So CA
      Wow the expert has arrived with such good advice. Its guys like this I wish they stayed in their garage and off the computer!!
      Feb 2011
      So CA
      Jeez then don't read it! Give the guy a break.
      Feb 2011
      So CA
      Don't mnd the other experts here, they are lying if they said they never faced a situation when they were learning how to wrench. Keep it up your learning loads as you make mistakes and figure it out. These other guys are too thick to get it.
      Quote Originally Posted by piratebaseball View Post
      Jan 2010
      Louisville, KY
      don't worry about it pirate, I'd actually like to give you props for posting with issues, you've probably helped someone else on here who may have the same problem in the future.
      David
      Beach Park IL
      Sanman, 2 days and 16 posts. Welcome to the board! I learn something new everyday, sometimes two things. You can quote this one as well and really get that post count up!
      David I agree, except the title of the thread is "ridetech outer tie rod stud clearance problem" implying that there is something wrong with the product. There was not. Within 20 minutes of posting the op replied saying he solved the problem by correctly installing the parts and figured it out on his own. There was some confusion due to a generic picture in the instructions and Bret said he is on it.
      The point is deal with a manufacturer first and at least give them a chance to help with your situation before you go to the forums.
      Donny
      Dec 2009
      Brunswick, GA
      Wow... To those who helped, thank you. To those who didn't, sorry for wasting your precious time.
      May 2002
      Northern California
      yeah i know i was just bustin balls where i see it needed. some guys need to try to be more helpful then hurtfull. you know what im sayin.
      Appleton WI
      Quote Originally Posted by davidk68 View Post
      David
      It's actually helping me quite a bit. I'm trying to find parts that will work together BEFORE I drop the coin rather than after.
      Piratebaseball-Could I get pics of the area that was hitting? Would a wheel with different backspace be better?
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      Beach Park IL
      They steering arms don't hit when installed properly. Check post #4.
      Oregon
      Kum-ba-yah...everyone sing along! (Padding my post count one post at a time)
      Tobin
      KORE3
      It's what I does.
      Appleton WI
      LOL! O.....K....
      I actually had noticed that he had solved the problem. I was actually looking for a picture of how this fit on a first gen relative to the inside of a 17" wheel.
      Jim
