      Jan 2012
      Car sat for 6 years
      Have a 67 chevy, small block, 4 speed
      Car has sat in storage for 6 years. Was not preped for storage. Still has old gas and oil in vehicle. Would like to bring car back to life but not sure where to begin and more important what exactly what to do. Any help would be appreciate.
      Auburn, CA
      1. Flush poo off the top of the engine and exhaust.
      2. Drain gas tank. Fill with fresh fuel.
      3. Remove plugs and shoot WD40 in the cylinders. Replace plugs.
      4. Remove dist and prime oil system after changing oil. If this has a flat tappet cam, be sure to put in the additive for the cam from comp cams or the like. After 6 years likely the cam is dry.
      5. Start up proceedure from here as if it is a new engine (time it and fire)
      Tim Tracy
      Jan 2012
      From the front of the motor looking towards the rear of the car, does the distributor turn clockwise or counterclockwise...
      Aug 2011
      Clearwater/FL
      Carb will likely need a rebuild and don't forget the fuel filter... and change the tranny fluid before you drive it
      88 Blazer sbc
      05 300c
      Midwest
      Also be sure to check all the coolant lines and hoses for cracks, top off coolant, grab a good battery, check batt cables.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
