    Results 1 to 15 of 15
      Dec 2011
      santa rosa calif
      18x9.5 on a 1970 nova
      i just started building my nova have a set of tsw 18x9.5 witha 20 mm offset and a 3" lip going to run 275 45 18 question is am i going to have to mini tub ?
      on a very low budget so brakes are goin to have to just be factory disc for a upgrade for now
      Long Beach, Ca
      You can fit a 275 in the rear without tubbing; but your backspacing will have to be spot on, which 20mm isn't and you will have to roll the inner fender lips or cut them off. The least you can get away with on a drum brake setup would be in the 4.75-5" BS (figure +.25" if converting to disk) which on your rims would be in the +0-6mm offset range (this will still rub on this inside).
      In the front a 275 can fit, but I don't have those particulars...
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Dec 2011
      santa rosa calif
      i'll be running 17x8 in the front on a staggered setup with a 20mm offset thinking 245 40 17 . thx mucho for the info i kinda figured i'd have to trim the outer quarter. hmm think i need to go with the offset dse hangers? or does that involve another fuel tank
      Long Beach, Ca
      No need to mess with the rear suspension, that has nothing to do with wheel fitment. You could probably run a 1" wheel adapter (not a spacer) and be ok, might need some mesaging with a BFH though.
      You'll want to run a 245/45/17 in the front, a 245/40 will be too short and look disproportionate to the rear.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Dec 2011
      santa rosa calif
      hmm stepping into another problem doin adapters is my wheels are a true 5x120 figured i could have the .6 machined out if it didn't fit but finding a adapter from 5.4.75 to 5x 120 is being a problem
      Long Beach, Ca
      They're not that hard to find. Just search Google for "5x4.75 to 5x120 adapters".
      One of the many that pop up: http://www.performancewheeladapters....0-Wheel/Detail
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Dec 2011
      santa rosa calif
      thx for bailing me out on this i'll get a set coming
      May 2002
      Northern California
      I was never able to get anything more than a 9" on my Nova's. 275's look good back there.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Cincinnati Ohio
      I ran a 17x9.5 with 6"bs on my 72 nova with stock wheel wells and housing.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Long Beach, Ca
      Quote Originally Posted by Bad94 View Post
      How?! That much backspacing would put it under the frame rail. You have any pictures?
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Cincinnati Ohio
      Quote Originally Posted by Nessumsar View Post
      Dec 2011
      santa rosa calif
      looks like i'm gonna be at about 11 inch's wide on the tires.
      i love the ride height on your nova bad i just hope i can get mine that low with the 18's
      May 2002
      Northern California
      Magic..... is that a half leaf suspension? Panard bar would be a must.
      Cincinnati Ohio
      That is what was on the car when i got it. It was the Fat Man Fab Wonder Bar.
      That is now off the car and im running a Air Bar with coil overs, Sorry to whore the thread, for more info check out my project thread.
      Dec 2011
      santa rosa calif
      after all the great info i have decided to change my front wheels to 18's to tho the problem is tsw only offers them in 18x8 with a 1.5'' lip and a 20 mm offset or a 32 or should i grab another set of 18x 9.5 's and run adapters up front to ?
