    Results 1 to 20 of 36
      Jul 2007
      Northern Virginia
      Custom Tubular Lower Control Arm?
      I purchased these custom control arms of eBay for my 1996 Impala SS a while back. After recieving my replacement ball joints,I went to pre-fitting them before getting the arm powdercoated I noticed that the diameter of my balljoints(S-10 and B-Body lower ball joints are the same) is smaller in diameter. The diameter of the hole in the control arm is 2.14"/54.61mm, the outside diameter of the lower ball joint is 2.09"/53.13mm.
      Does anyone have spec sheets/cad for ball joint?
      Name:  Photo Jan 25, 17 37 51 (Large).jpg
      Ray
      1996 Impala SS aka MistreSS (7800 original miles)
      LPE LT4 Heads/Intake
      Powerdyne Supercharger\T-56 Conversion
      MistreSS Updates: https://www.pro-touring.com/showthre...light=mistress
      Jul 2007
      Northern Virginia
      The press-in Moog K-6141 may work in the lower control arm as it measures 2.190 OD. But the problem now is that its a 5/8 taper shaft vs my 9/16 OEM one.
      Would it be feasable to ream my OEM spindle to accept the K-6141?
      Ray
      Oct 2009
      New Derry, PA
      The 2.19 will be too much press fit unless you open the hole up a little.
      Just my opinion, but I'm not in love with how far the hole sits out from the ends of the tubes.... How thick is that plate?
      Jul 2007
      Northern Virginia
      Quote Originally Posted by exwestracer View Post
      I will get the thickness of the plate in a few.
      Ray
      Jul 2007
      Northern Virginia
      I went out and measured the plate thickness. It measures at 0.501
      Ray
      Oct 2011
      Philipsburg, Pa
      Also, can you send a pic of the entire arm? I'm curious.
      thanks
      ramey
      Technical Support
      UMI Performance, Inc.
      [email protected]
      814.343.6315
      Join us on Facebook!
      May 2011
      Central FL
      Maybe write the guy who makes/sells them and ask which ball joint was used to determine the ID of the arm?
      - David
      1967 Camaro - In remembrance of my friend Scott
      Jul 2007
      Northern Virginia
      Check here for control arm pictures:
      https://www.pro-touring.com/showthre...581#post872581
      If you need better photos let me know and I can upload them tonight.
      Ray
      Mar 2010
      Okinawa, Japan
      Ummm I would double check at least the thickness measurement, no way that's 1/2" plate maybe 3/16" (.1875) but 1/8" (.125) wouldn't surprise me.
      Oct 2009
      New Derry, PA
      Most of the lower arms you see out there have some sort of reinforcement out closer to the ball joint (like your upper arms). If it is 1/2" (!) it might be strong enough. That is one hell of a hinge point with all the corner weight pressing against that narrow piece of flat metal...
      Jul 2007
      Northern Virginia
      I will recheck the measurement.
      Just to clarify, you want me to measure the thickness as shown it the "red" circle?
      Ray
      Mar 2010
      Okinawa, Japan
      Quote Originally Posted by SSTuner View Post
      Ok I think you are measuring what I would call width here, I'm not as concerned with the distance between the concentric circles but that actual plate thickness. Though in this picture it does look thicker than the others... I'm still guessing 3/16" but even if it's 1/4" I would want some gusseting, flat plate just doesn't resist bending very well.
      Oh and you can get a reamer for your spindle pretty cheap from circle track suppliers, that's what I would do.
      Mar 2004
      Mid-Michigan
      Looks pretty thick to me. It may be good to provide some gusseting back to the tubing. Like Ray said a lot of load goes through that narrow section.
      This is what I did when i\I designed and built the LCA's for the van.
      I used a lower ball stud cup from A & A engineering that fits the 6141 LBJ and plated it back to the tubes. The joint you are using is actually "borrowed" from the astro van application. The wagons and police cars were breaking the 1/2 inch studs so they up-sized them to the 5/8ths inch Astro LBJ.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Jul 2007
      Northern Virginia
      Ray and Mark, I am going to take your suggestion and weld in additional gusseting/bracing as soon as I get the ball joint issue squared away.
      Ray
      Mar 2004
      Mid-Michigan
      If you are running actual stock SS spindles they should already have the 5/8ths ball stud. That was a running change as far as I know for the wagons, police and SS cars.
      Mark
      Mark:
      Jul 2007
      Northern Virginia
      The 9c1 and wagons got the 5/8 upgrade while the SS stayed with the 9/16 ones. This included the control arms and spindles. Not sure why the SS didn't go that way.
      Ray
      Mar 2004
      Mid-Michigan
      Get yourself some wagon or Astro front spindles. In fact... I have some astro spindles I just yanked out of the van. Need some cleaning but you could have them for 50 bucks and shipping...
      Mark
      Mark:
      Oct 2009
      New Derry, PA
      Mark, where does the spring load your LCAs?
      SS Tuner...at this point reaming the spindles to the bigger ball joints might be your best option. Trying to open that hole up and keep it round and concentric is going to get tricky...
      Mar 2004
      Mid-Michigan
      [QUOTE=exwestracer;876135]Mark, where does the spring load your LCAs?[QUOTE]
      Vari-Shock coil-overs.... The pic you see doesn't have the shock mounts installed yet.
      Mark:
      Auburn, WA
      IMO that design isn't suitable for the weight of your vehicle.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
