      Aug 2001
      Connecticut
      ls7 oil pan question
      Ok, I'm considering joining the dark side... losing the carb and the gen 1 stuff and going ls7 on the 68. It looks like the ATS oil pan is no longer offered. Has anyone else found an option for the 1st gen camaro with the stock/modified subframe? (notching the subframe comes to mind?) thanks- Dan
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Miamisburg, Oh
      Pics coming to you this weekend Dan, sorry for the delay.
      I'm using the stock LS7 oil pan with some mounts supplied by Kooks (with their headers). Seems to clear just fine right now, including fittings for the lines to the oil tank. (I'm still playing with varying the frame stands and front/rear bias of the mounts)
      69 RS
      LS7, T56 and other cool stuff
      Back on track in late 2020!
      Build Thread
      Aug 2001
      Connecticut
      Thanks Allan, I started pulling sheet metal off tonight, I figure if the nose is off it will be a lot easier and I'm less likely to damage the paint. Also it's about due for some fresh satin black in the engine bay anyway.
      What did I get myself into?? I must be nuts... Dan
      2006 Corvette Z06
