    Results 1 to 20 of 20
      Chicago suburbs
      Streetable Roll Bar Kit
      I am doing some mini tubs in my 1st gen and figure now would be a good time to install a roll bar. It will be for chassis stiffness and some safety. Here is the problem- I live near Chicago and don't know any fabricators who would be able to build one, which is fine because I kind of like to do things myself. Also, my car is apart and I really don't want to tow it to some shop that I don't know. My garage is pretty well equipped and welding is not an issue. The one thing that I do not have is a tubing bender, so I am looking for a WELL FITTING kit. I can't seem to find much out there, though. The way I see it, I can either go with the DSE kit or a bolt in autopower bar. I really like the way the DSE kit fits, but the fact that it is not DOM tubing is ridiculous for the price they are asking, plus it has no door bars. I can't find a pic of the autopower bar, so I don't know how it fits. I would rather weld one in that could be built onto later if I wanted to.
      Chicago suburbs
      Anybody else here ever install a rollcage/bar without access to a tubing bender? I can't belive that the overpriced (but not legal) DSE bar is the only thing out there for these cars. Don't get me wrong, I really like DSE stuff, but for that price it should be DOM or chromoly! I may end up gritting my teeth and buying it anyway, because it seems to fit so well. I'm considering the autopower bolt in cage, but can't find any pics. I think it attaches to the wheelhousings though, which seems a little weak
      Oct 2007
      Atlanta
      Buy a bender, make your cage the way you want, then resell the bender. They don't depreciate much. Try some of the 4x4 sites, there's always 3 or 4 guys trying to sell theirs. Personally I wouldn't put any cage in unless you plan on wearing a helmet when you drive, but that's just me and my fragile cranium. It doesn't like smacking into steel tubing. ;)
      Sep 2011
      Dana Point, California 92629
      Try this one if you don't like DSE.
      http://www.ridetech.com/store/tigercage/
      Chicago suburbs
      I like your idea of buying and reselling a bender, but I know that there are a lot of guys out there who bend tubing better than I do. I've never done it before and I don't want to practice on my car. I prefer to do 95% of the work on my car, but a roll bar falls into that 5% that I don't do. I want to install it, and I prefer a weld in bar. I'm not doing a halo bar, just the main hoop, crossbar, rear supports, and possibly door bars- so I don't see a chance of my head hitting any tubing, it should hit the headrest first. There are seemingly endless suspension options for these cars, and almost any mod you can do to it is full of choices. I can't believe the roll bar options are so limited. As far as the tiger cage, I like the overall shape of it and I'm sure it's well built, but it kind of reminds me of something built out of an erector set. I've searched and googled but can't find much. I figured I wouldn't be the only one on this forum to run into this problem. I think a weld in bar would be a great way to add strength to these cars- I'm surprised its not more popular.
      san diego
      Side note: autopower is only legal for SCCA, not NASA nor NHRA and most require 1.75" with .120 wall and DOM.
      Try Chris Alston or autoweld. I know autoweld would have it and it would fit will a little fitment like cutting the hoop shorter, I think they leave all bars long so the installer can make it fit as tight as possible.
      Chicago suburbs
      Thanks- I'll check them out.
      Oct 2007
      Atlanta
      S&W Racecars has a decent reputation as well and lots of variations of cages for you to pick from.
      Chicago suburbs
      Autoweld has decent pricing and a lot of options, so I'm considering them. The only problem is they don't have any pictures, just their word that "it fits good". I really like the fit of DSE, and its the only one I can find pics of. Anyone here have any pics of their roll bar? I'll try S&W next. I'm trying to avoid buying a generic fitting roll bar.
      san diego
      I bought just the main hoop for my 65 mustang and it fit great.
      Dec 2010
      Fredericksburg, VA.
      Competition Engineering has been selling roll bar kits for years. Check with Summit and Jegs. There are a number of racecar builders around Joliet as I recall.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Chicago suburbs
      So I'm calling around, and I'm being told that if you have a roll bar, it needs to meet NHRA specs, regardless of what e.t. your car is capable of. Can I eliminate the rear seat and add a 4 point bar or no bar and be legal? If I add door bars, they need to be straight, which really limits the street ability of the car. It's mainly a pro touring type street car, but I may want to take it to the track now and then. The only tracks near me are drag strips. So if I show up with my SBC powered Camaro with no bar I'm ok to run. With a 4 point am I legal? What if I add low door bars and call them "rocker supports"? I know that I can ad swing out door bars, but I really want the extra stiffness of some welded in low door bars. Could I also add a swing out bar and just remove it for the street and be legal?
      Mar 2010
      Okinawa, Japan
      I'm pretty limited to drag only tracks around me too and went with the removable door bars. Completely legal at the track ant totally out of the way for DD. One note though, I run at least a 4 point as a minimum even on the street to ensure I couldn't come in contact with the main hoop.
      Here is the main hoop and NHRA legal down bars:
      And here are the door bars installed:
      san diego
      Quote Originally Posted by another69 View Post
      From my understanding, if its stock you can get away with a lot. Once you change something it needs to pass tech.
      A non-legal roll bar is worse than no roll bar.
      Chicago suburbs
      carguykeith-
      That roll bar looks good, that would be the type of removable door bar links that I would use. I want to run another bar close to the rocker from the main hoop to the front floorboard that would be non removable, I wonder if having that extra support would pass tech. If I could do that, and just put on the door bars when I'm at the track that would work for me. Do your rear supports pass tech? I thought they could not have any bends. I've checked the NHRA rulebook, and it leaves a lot of questions. Their "acceptable" roll bar is more of a 5 point. If I go through the trouble of welding in a roll bar, it may as well be legal somewhere.
      san diego
      NHRA allow one 30* bend in the main hoop support. I am not sure if the door bar can be a swing out.
      Chicago suburbs
      30* bend might do it. I'm not planning on running a rear seat, but tucking the bars up close to the headliner would be great for aesthetics and the ability to put it seat back in later if I want to. I'm pretty sure they allow a swing out door bar, but I better look into it. Like you said, a non legal roll bar is worse than no roll bar at all (in their eyes). In my opinion, as long as the welds are strong, almost ANY roll bar is better than no roll bar- but I don't make the rules.
      Chicago suburbs
      So it looks like with a hardtop you need a roll bar at NHRA specs if your car runs faster than 11.50. If you run, say, a 12.50 and show up stock you can run, but if you show up with a roll bar and run 12.50 you can only run if the roll bar is legal. Do I have this right? I'm probably putting too much thought into this, but the car is really mainly for the street, I am not building a drag car. I don't want to compromise street ability for the sake of running down the strip a couple of times a year. I would go more for a road race cage, but there are really no tracks around here
      Southern Indiana
      Heck email NHRA if those are local tracks, they can tell you if a cage/bar/etc are ok if your in class that doesnt require it.
      Lee Abel
      AFTERMARKET PERFORMANCE
      san diego
      I have read through all of the sactioning body's rule books. SCCA does not need a cage or roll bar until you are on slicks in certain classes, some convertables need them. NHRA is 11.50 like you said. NASA is similar to SCCA, but they have more stringent rules on their cages. The RTTX series need to have a 3pt harness. If you plan on having a a 4pt or 5pt harness you should have a a roll bar to attach the harness to.
