    Results 1 to 20 of 40
      Greenwood SC
      Ridetech True Turn With ATS Spindles Brake Problem
      So I installed the true turn system over the weekend on my 69 Camaro and I'm using speed tech a-arms and ATS spindles and now my Baer brakes that are made for the spindles don't fit. The bottom of the caliper hits the end of the tie rod..... Any suggestions or help will be appreciated
      alpine ca
      i just have a ? due to i dont know but what ive heard but why did you get the true turn (just for the bigger wheel and tire) ats spindles i thought fixed the geometry of the steering?
      john
      BUILD LINK
      Central CA USA
      Why would you use the True Turn system with ATS spindles? The true Turn system is made for the Ride Tech spindles.
      David
      Nov 2011
      From what Marc at s c and c told me is that the tru turn was made to fix the geometry problems that the ride tech spindles caused by their design. ATS spindles already have that stuff fixed.
      Dec 2009
      knoxville, tn
      sell the ats spindles, buy ridetech spindles and buy more mods with the rest of the money....problem solved.
      or
      keep the ats spindles and send me the tru turn kit for disposal since it's used and non returnable.
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      "attack life....it's going to kill you anyway."
      Greenwood SC
      I bought the true turn to fit a 10" wheel and the car came with ATS spindles and the brakes that fit the ATS spindles so if I get the ridetech spindles the brakes want fit
      Jan 2009
      Quote Originally Posted by jeremy30thz View Post
      I'm guessing that this is what is going on:
      • The TruTurn setup is intended for the ridetech spindle.
      • The ridetech spindle uses factory steering arm mounting holes.
      • The TruTurn setup reduces bump steer by using a custom steering arm and a custom center link bracket. The point of this is to locate the tie rod in a specific location to minimize bump steer.
      • The AFX spindle is intended for use with a stock steering arm.
      • It reduces bump steer by changing the steering arm mounting holes, thus moving the steering arm, and locating the tie rod in a certain position to minimize bump steer.
      • When you use the AFX spindle AND the TruTurn steering arm, you are "double compensating" - the AFX spindle moves the steering arm (and thus the tie rod) to the correct location, and then the TruTurn steering arm moves it again (to an incorrect location).
      • This overcompensation is causing an interference between the tie rod and the caliper.
      One possible solution is a custom billet steering arm that un-does the AFX spindle adjustment, but it just may not be compatible due to the brake setup. Not sure.
      Dec 2009
      knoxville, tn
      the ats spindle uses a corvette brake set-up. baer also makes your brake set-up to work with stock spindles. so all you need to adapt your brakes to ridetechs spindles is a pair of brackets from baer or kore 3.
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      Vacaville CA
      Maybe I've been missing information this whole time. But buy ridetechs spindle and true turn to correct the suspension and steering geometry then buy adapters for the vette brakes..... or just buy the ATS spindles and you're done??? Almost sounds like a waste to even bother with ridetech.
      Cincinnati Ohio
      I have a true turn set up on ats spindle sitting in my shop right now. I know what you are talking about. I will post a few pics later of how i fixed the problem. Also has C6 ZO6 brakes.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Greenwood SC
      Quote Originally Posted by Bad94 View Post
      Please tell me you have a solution
      Dec 2009
      knoxville, tn
      Quote Originally Posted by Black93GT View Post
      the full tru turn kit comes with their spindles. you can buy the kit without spindles though. this is meant for people who already have the ridetech spindles like me, not for people with other brands. the tru turn info on ridetech's site plainly says that the tru turn will not work properly with other brands of spindles.
      evidently a 10" wheel won't clear the ats spindles either or the gentleman would not have bought the tru turn kit.
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      St George Utah
      Quote Originally Posted by SR71 View Post
      Actually a 10" wheel will work on the ATS Spindle. if you are using a 18" wheel, DEPENDING on what steering arm you have, there are a few 3-4 different lengths and heights, we have found the best fitment is available using the unisteer rack and steering arm set up.
      The Truturn has been tested with the ATS spindle, and it is far from ideal, not to mention the caliper fitment issue. I had questioned Brett about the caliper fitment with the TruTurn and all their testing showed NO caliper issues. Now they apparently did not test it with the AFX spindle.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Greenwood SC
      Quote Originally Posted by killer69 View Post
      Hey Blake I was going to call you today and see if you had a solution for me but since your here.......I have the ATS steering box from you guys can you tell me what steering arms I can use with a 18x10 wheel with 6.75 backspace, if I can just replace the steering arms I will sell the tru turn system
      Dec 2009
      knoxville, tn
      I stand corrected by the man from ats himself.
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      Vacaville CA
      Correct me if i'm wrong... but the ATS spindle comes with the hubs too?? Sounds like i need to return the ones i jsut ordered in exchange for ATS spindles.
      You could swap the spindles side to side. This would move the calipers to the leading side of the spindle.
      Brian P
      Greenwood SC
      Quote Originally Posted by BrianP View Post
      Have not thought about that, anybody know if this will work?
      St George Utah
      No reason it wouldn't work.
      Blake Foster
      435-628-4300
      St. George Utah.
      St George Utah
      Yes they do come complete with hubs.
      Blake Foster
      435-628-4300
      St. George Utah.
