    Page 2 of 2 FirstFirst 1 2
    Results 21 to 29 of 29
    1. #21
      Jun 2006
      Mason TN
      I too have the Fast Trax tool, I also picked up a set of turntables from HF a few years ago and a toe gauge. I was able to muddle through the alignment after setting my suspension up but have only done it twice. I need more practice to really get comfortable with it.
      What I would like to see is a list of tips and tricks for doing home alignments. maybe you guys with more experience can share some knowledge? One thing that still confuses me is setting the alignment with adjustable upper A Arms? I have adjustments on the front and rear of the arms and get confused on which side to adjust.
      Another thing I think would be useful is setting the suspension up at baseline, by this I mean setting everything adjusted to the center of the car, front and rear tires lined up properly front to rear then making the front adjustments.
      Am I off base on this?
      Also, I did not mean to highjack the thread so if this is worth of it;s own thread feel free to move it.
      Thanks All.
      1986 Monte SS, 427 sbc, Victor E manifold, FAST TB, FAST XFI, T56 6spd, Moser M9 rear 3:70, SC&C G5, Spohn lowers, Pole Position Uppers, Alston Coil Overs, Pirelli all around
    2. #22
      Nov 2002
      state of confusion
      Quote Originally Posted by John S View Post
      Adding or subtracting shims equally will affect camber without causing caster to shift. Unequal changes in the shim stacks affects caster and will generally cause changes in camber as well. So if you go after caster first, once you get that set it'll only be a matter of adding or subtracting equal thicknesses of shims to put the camber where you want it.
      Assuming that you have the ability to adjust the rear axle for lateral location and thrust angle, yes.
      Norm
      Gone but not forgotten dep't:
    3. #23
      Jun 2006
      Mason TN
      Quote Originally Posted by Norm Peterson View Post
      Norm
      Norm,
      In the case of a solid rear axle car such as my Monte is there any benefit to knowing just how much difference there is in the rear track from the front?
    4. #24
      Apr 2008
      Sorry to ask another question but this thread has convinced me to do my alignment myself. I looked around a little bit and the alignment gauges I found only work on either steel wheels or step lip wheels. What is out there that will work with soft lip wheels?
      Mike A
      69 Chevelle
      496 Big Block
    5. #25
      Nov 2002
      state of confusion
      Norm,
      If nothing else, it would help you set up parallel strings if that's your method for checking toe. With the strings, you can also check rear toe, which may not be precisely zero like you might think.
      Norm
    6. #26
      Nov 2002
      state of confusion
      Quote Originally Posted by 69496 View Post
      With care, something like this, with a steel or aluminum extension of appropriate length, ought to work. Worst case, you might have to add some blocks to stand the whole thing out past any bulging wheel centers or spokes. You do have to be careful to keep the angle finder 'plumb' as seen in side view, so a steel angle will let you stick a magnetic level to it for better than an "eyeball vertical".
      Norm
    7. #27
      What I do for the toe setting is to use laser levels. The small ones that project a vertical line/beam. Set them on a jack stand even with the center of the rim, one on each side at the rear of the car. Shooting the beam toward the front of the car.
      Using a metal 6" rule they are set parallel to the rear wheels. Then adjust the front toe making it square with the rear axle. A tip is to use something to hold the steering wheel while doing this. Otherwise the steering wheel can move and you end up with it being off-center.
      The parallel string method also works, but I kept tripping over the strings. And doing a rear-steer car (aka, 1st gen f-body), they are in the way (even more so).
      Turntables make a world of difference. Until I obtained a set I was unable to get repeatable and decent results.
      Bob.
    8. #28
      So. Cal.
      Hey Mike. I have the "soft lip wheel" also. Thats one of the reasons I made my hub mounted rig. I think longacre sells a hub mount for their various systems. Might give them a look. JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
    9. #29
      So. Cal.
      Thank you Sir. Its always nice to get a lil confidence build from my peers!! As I muddle through the next step in the MASSIVE learning curve that IS wrenching on cars Im a Newbie. First time car monkey, wrenchin on cars, learning every day and having a LOAD of fun!!! JR
