01-13-2012 #1
wheel and tire selection for 68 GTO?
Hello, I have searched around and kinda found what I am looking for and think these should fit but I wanna double check with some wheel and tire guru's before I pull the trigger...
The car is a 68 GTO w/ full suspension from CPP drop spindles. 2'' lowering springs and coil overs in the front w/ 2'' drop springs in the rear and disc brake conversion from Matts Classic Bowties (right stuff detailing kit) I read the drop spindles will move them out 3/8'' in the front.
I have read the specs every which way and am not sure the back spacing and offset but the make and model selector chose them for my car. But I am unsure since I don't have a stock suspension anymore....
So I need to know if this wheel and tire combo will work?
The rears http://www.discounttiredirect.com/di...205&wd=18&rw=8
http://www.discounttiredirect.com/di...18&rw=8&cs=255
The fronts http://www.discounttiredirect.com/di...18&rw=8&cs=255
http://www.discounttiredirect.com/di...17&rw=8&cs=255
Any help is greatly appreciated or even a point in the right direction! Thanks Andy
