      West of St. Louis. O'Fallon, MO
      GM Techs help with Acadia
      Our Acadia is acting strange. The power steering quits while driving followed by service stabilitak, service traction control, service power steering. Any Ideas? Got to be a sensor blimp somewhere, because after you shut is off it resets and your good again for a while.
      Jeremy Holman
      '73 Camaro RS Z/28. 388 cid, 200-4R Art Carr, C5 brakes, Hydroboost, Budnik Hammers, PTFB GT Springs, Subframe Connectors, Solid body bushings, G Braces, Front and Rear Sway bars.
      Benicia, Ca.
      You really need a scanner...GM tech 2 is the best. Might have to go to the dealer and have them diagnose then you can do the fix. The canbus in the new GM vehicles is VERY complex!
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
      Apr 2011
      mass
      Customer Concern: The Service Power Steering message is displayed. Antilock Brake System (ABS) DTC C0450.
      Average Reported Mileage: 51234
      Tests/Procedures: 1. Check the wiring harness for the Power Steering Actuator near the left side half shaft. Inspect for damaged wires at the power steering gear to the Magnasteer actuator. Brown and White wires.
      2. If the harness is OK, disconnect the Electronic Brake Control Module (EBCM). Ohm check the Power Steering Actuator between pin 5, a White wire and pin 28, a Brown wire. The resistance should be 5 - 10 ohms. Repair as required.
      3. Clear the DTCs. Testdrive the vehicle.
      4. If the DTC clears but the message or lights remain on, refer to GM PIT4665C for clearing procedures.
      Paul
      66larkgs
      turbo nailhead
      They replaced the Electronic Brake Control Module (EBCM). So far OK
      Jeremy Holman
