      Feb 2009
      Mobile ,Al
      drip rail seam sealing
      Should the 3m two part seam sealer be put on bare metal and then primed or primed and then the sealer?
      Tony
      Dec 2009
      Carson City, NV
      Most seam sealers I've dealt with went on bare metal. but check the technical data sheet (should be available on the 3M website) for the particular seam sealer your using to be sure.
      Oct 2009
      CT.
      Seam sealer does not have a rust preventative. It is not meant for a direct to metal use. It just stops the penetration of water/moisture. I would definitely do it over the primer. Plus it looks better that way.
      Glenn
      1955 Chevy BelAir
      1951 Chevy 3100
      1987 Chevy Silverado
      My last project....
      https://www.pro-touring.com/threads/...my-72-Maverick!!
      Sep 2007
      Denver
      Read the tech sheet. I know fusor goes over primer.
      David Beckstrom DVM
      South Haven MI
      I've always done Primer then Seam sealer
      Vince
