    Page 22 of 29 FirstFirst ... 12 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
    Results 421 to 440 of 573
    1. #421
      Jan 2011
      Boston, MA
      I got the new Denny's Driveshaft installed.
      I cut my exhaust pipes back an inch or so to account for the new headers and new engine position and fired her back up for the first time this year. Ran like a charm. I took it for a couple of gentle laps around the neighborhood and tightened down the suspension.
      I'm going to leave it until I get back from the trip and go through all the bolts I loosened/removed over the winter to make sure everything is torqued to spec, and then I should be good to go. The exhaust is actually good enough that I could drive it as is, but since I have the new Magnaflow X-Pipe already, I'll get it to the exhaust shop as soon as they have some free time.
      It was good to get her out for a quick spin, cruising season is almost here!!!
    2. #422
      Aug 2008
      jacksonville,fl
      Lookin good man, I'm sure you'll be itching to take a real drive in it once you finish checking it over::::: after vacation.
      Considering going with Denny's myself for a shaft. Thinking about an aluminum one though. My old salvage yard shaft has a little annoying vibration at higher highway speeds with my 3.73's & double overdrive.
    3. #423
      Jan 2011
      Boston, MA
      Quote Originally Posted by jlcustomz View Post
      I was going to go aluminum and Denny talked me out of it. He said the steel was stronger, cheaper, already had the 1350 U-joints, and could be shortened if I ever needed to change it.
      My buddy just ordered an aluminum one for his '69 Camaro with a similar LS swap. It should be about 10 lbs lighter than mine. I asked Denny about running an aluminum one to reduce the risk of vibrations and he said mine won't vibrate. High speed balanced up to 10,000rpm.
    4. #424
      Jan 2011
      Boston, MA
      Alright, so this is bad right? Here's a shot of the McLeod hydraulic MC that I trashed because I didn't install a clutch pedal stop. I'm pretty sure the combination of clutch fluid and metal shavings is a bad sign...
      I ordered a replacement MC direct from McLeod. The part number is 139310 if you go through Summit or Jegs. It's Z-260-12707 direct from McLeod:
      You don't get the anodized housing, just the MC itself. It is attached with 7 allen head bolts. Of course it comes with the wrong pushrod installed. The new one had a straight pushrod, and the 67-69 Camaro uses a curved one. Direct replacement from the factory. Why would it be simple, right? It's just held on with a snap ring, easy change. New MC on top, old one on bottom:
      Here's the new one all re-assembled:
    5. #425
      Jan 2011
      Boston, MA
      And to prevent that in the future, here's my version of a clutch pedal stop that I made from stuff I picked up at Lowe's.
      I used a 3/8" elevator bolt, a 3/8" grade 5 bolt, a 3/8" coupling nut (that I cut down to fit), a couple of stainless 3/8" fender washers and a 3/8"x1" grade 5 bolt:
      Here's how it will work:
      I mocked up the coupling nut and the elevator bolt, and pushed the clutch pedal down to leave an imprint of the nut on the sound deadener:
      I drilled a 3/8" hole through the firewall, assembled everything and red locktited the bolt through the firewall into the coupling nut. I then used one of these:
      On top of the elevator bolt, so it wouldn't be metal on metal contact. I can adjust the elevator bolt out an inch if I want to shorten the throw of the clutch in the future. They also had some made of rubber and slightly thicker, which I'll probably pick up next time I'm at Lowe's, but this works great as is:
    6. #426
      Feb 2007
      Tinley Park, IL
      Same exact thing I did for a clutch stop on mine. Except I used a thick rubber foot you would put on the legs for tables/chairs as a padded stopper over the elevator bolt.
      Nick ~
      1969 Cutlass
    7. #427
      Jan 2011
      Boston, MA
      Alright, I'm trying to tackle some small projects that even if I screw them up, won't keep me off the road. If the weather holds out, there's a Cars 'n Coffee up in NH that I'd like to hit this weekend, and the Kingpins Season Opener is in Metheun the following weekend.
      I finally got around to installing the front spoiler I got for Christmas. I just went with a standard spoiler instead of a pro-touring style one. I figure I'll curb it at some point and be much happier replacing a $40 part instead of a $300 one.
      Here's the diagram I used:
      Of course nothing is as simple as I'd expect. Apparently my Camaro had a front spoiler at some point, so the holes were already there, but someone used oversized sheet metal screws, so the screws that came with the kit were useless. I drilled the holes in the valance out to 1/4" and used some 1/4" stainless button head bolts.
      Also, the braces were too short to line up with where they should hit on the fenders (1), but I've read about people curbing the spoiler with the braces and damaging the fenders. I decided to just use the two outer braces and drilled a couple new holes in my subframe (2) and attach them there.
      Anyways here are a few before and after photos, not the best lighting. I like the new look, it definitely needed it. I'll probably remove the front licence plate at some point.
    8. #428
      Aug 2008
      jacksonville,fl
      Looks more complete with spoiler.
      For years I've thought about making a lower spoiler mounted on a slotted & spring loaded assembly to take some of the initial shock of a hit off of it. Would at least be helpful for low speed parking lot bumping.
      Just a thought, If you drive at all, spoiler damage will eventually happen.
    9. #429
      Dec 2009
      It does look more complete.
      My last 68 I must've destroyed four of those suckers just in my driveway alone.
      I do think GM found some downforce was created even with the plastic spoiler, so spring loading it might defeat the purpose (unless it's strictly a street car).
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
    10. #430
      Aug 2008
      jacksonville,fl
      By spring loaded, I meant the brackets being on slots, able to slide rearwards with enough force from being hit. Not changing angle. Would have to be fairly stiff springs. This would be most useful in driveway, parking lot bumper/ curb situations.
      Just another thought from the mind of a weird person who doesn't sleep much.
    11. #431
      Jan 2011
      Boston, MA
      If I could fabricate like ljcustomz, I probably would have done something similar to the Spoilers by Randy design. I'm just going to consider the spoiler an expendable part, like brake pads or tires. I'll probably pick up a spare to keep around for when I crack this one.
    12. #432
      Grain Valley, MO
      Thanks for the detailed pics on the clutch pedal stop. I'm at the point where I need to get that installed on mine.
    13. #433
      Jan 2011
      Boston, MA
      Quote Originally Posted by Mizzouri View Post
      No problem.
      I changed out the pad on the new clutch stop for a rubber one (got it at Lowe's). The first one's I used were very thin and seemed like they'd wear out fairly quickly. It also had a very hard stop (felt like metal on metal).
      This project took about 30 seconds to scrape the old adhesive off, and another 5 seconds to put the new rubber pad on.
      Here are the pads I used:
    14. #434
      Jan 2011
      Boston, MA
      I also stopped by the exhaust shop. I'm going to drop the '67 off on Tuesday to have the old Flowmaster H-Pipe setup removed and the new stainless Magnaflow X-Pipe installed. They are going to add a set of flanges at the front so I can drop the intermediates and X-Pipe out easily if I want to. The Doug's headers do not come with flanges of any kind. Everything else will be welded solid back to the existing mufflers. There's a joint behind the mufflers that is band clamped in case I want to drop them.
    15. #435
      Nov 2009
      Country Flag: Argentina
      Brent the car keeps getting better and better. Can't wait to see pictures of the exhaust. Do you happen to have the part numbers? I am thinking in building my own exhaust as well.
    16. #436
      Aug 2008
      jacksonville,fl
      Band clamps have worked great for me at my headers for years now. FYI bands are stainless ,most bolts are not. Coat em with anti seeze some time soon.
    17. #437
      Jan 2011
      Boston, MA
      The Magnaflow Tru X-Pipes are the universal fit 2.5" ones. Part number 16404. Just from the headers to the mufflers. I'm leaving the mufflers and tail pipes as is. The mufflers are already Magnaflows, and the tailpipes are Flowmasters.
      When I first had the exhaust done, we tried the Magnaflow 15896, which is the full X-Pipe system from the headers back out the rear. The Magnaflow tail pipes did not work with the Hotchkis rear sway bar. So I had them install the Flowmaster H-Pipe setup, but replace the mufflers with Magnaflows. Then an engine swap and a new set of headers later, the H-pipe setup has been hacked up a few times and there are some exhaust leaks...So that's why it's time for a change.
    18. #438
      Jan 2011
      Boston, MA
      Once they're installed on Tuesday, I'm going to paint the flanges with some high temp silver header paint.
    19. #439
      Jun 2012
      So you basically pieced together your own exhaust. Nice. I did the same thing, couldn't bring myself to drop 700 on a flow master 3" system for a street beater car, so I bought thrush chambered mufflers and jegs madrel bent header extensions and went to town. Your car is looking good, 67 is my favorite car year and the rs is my favorite trim option for camaros. Keep us posted.
    20. #440
      Jan 2011
      Boston, MA
      I got the new Magnaflow X-Pipe installed today. They welded a set of flanges to the back of the collector and to the front of the intermediate pipes. All the seams are welded. They did a decent job, but I'm not sure I would have been so liberal with the BLACK spray paint on all the seams. I'll probably hit it with some ceramic silver header paint to blend in a little better, but at least they didn't leave the welds to rust.
      It sounds great, and better yet, no exhaust leaks! I'll do a video comparing it to the old H-Pipes in a few days. But from inside the car, you can't really tell much of a difference between the X and H pipes (other than the exhaust leaks are gone).
