Thread: Please help, I need advice
07-07-2005 #1
Ok, I did the four wheel disc kit from Wilwood (converted from four wheel drum)
Do I absolutely need to install the proportioning valve?
The reason I ask is because I cannot do a double flare to save my life
So if I need it, can I bench bleed the master with regular brake fluid just to get the car somewhere that can install the inline prop. valve, then have them bleed the regular fluid out and have them put the Wilwood fluid in?
I am REALLY wanting to finish my car this weekend and this a big hitch in my get along.
Ed
07-07-2005 #2You could, but I didnt say it! The prop valve just keeps your back tires from locking up before the fronts.
Justin, 68 Camaro Update:5 speed is in and neighbors are pissed!
07-08-2005 #3Thanks for the reply
