      Nov 2009
      Ca
      need fast ex efi help! new install
      We installed an ez efi on a 67 firebird with a Pontiac 326. Mild cam, stock heads, headers, noting too crazy. After installing the efi, we could only get it to run with the throttle held open a little. After looking over the complete engine and finding nothing wrong we installed a carb we had on the shelf and it fired right up and had a good idle. So that leaves us with the efi set up. We reinstalled the efi. decided to unplug two injectors and it fired right up and idles good. While running we plugged in the other injectors and it got too rich and killed the engine. We next took another fast ez efi computer we had and tried that with no luck. Then tried another fast ez efi throttle body we had, with no luck. We then lowered the fuel psi from 43 to 30 with no change at all. Then a new O2 with no luck. We then checked all the wires from the connector at the computer to each connected at the throttle body for continuity, all good.
      So now I'm stuck! And need more help.
      While running on two injectors I looked at the live data on the hand held and from what I see all in good. No TPS movement at idle. AF was reading around 13.3 at idle on a cold block. The RPM was reading 700 to 750.
      What could be causing the efi to dump soo much fuel. Do all 4 injectors always batch fire? Even at idle?
