    Results 1 to 20 of 31
    Thread: Welding Helmet
      Nov 2004
      Eastern Washington
      Welding Helmet
      What is the best welding helmet you can buy? I want one with a larger viewing screen and auto darkening. If money was no object up to $400 eBay bucks, what is the best you can get?
      Beaufort, SC
      '72 Chevelle- 4 wheel 12" Discs, Konis, Hotchkis springs (shortened an extra coil up front), 17" Cragar Soft 8's with 245's in front and 275's in back. ---STILL IN PROGRESS---
      Jun 2002
      Long Island, NY
      I've got a hornel spedglas and I'm pretty happy with it. It's supposidly a top of the line hood. I think I paid $279 for mine. cyberweld.com or something like that is where I got it from, they were by far cheaper than anyone else.
      Big Stone Gap, Virginia
      Speed of LIGHT!!
      Haven't heard of anything faster than the speed of light yet?? Something to consider when buying the auto darkening helment!! Time will tell the story on them!! Maybe I'm just old school though.
      Mark
      Nov 2004
      Eastern Washington
      I think I want the auto darkening helmet cause I cannot see out of the others. I have basically gotten to the point where I put the Mig where I want it and turn my head away and shut my eyes before I pull the trigger. I really hate doing it, but I cannot see otherwise. Plus I want added protection from welding sunburns
      Miami, Florida
      I've always wondered about the point that Mark is making? What happens to your retinas between the time that the initial weld arc light gets through the window before it darkens? Do you start the weld with your eyes closed or your head turned? What effect does this brief lack of attention to the weld process have on quality, particularly if you’re working on a plainly visible weld that needs to be purdy!
      Kevin.
      69 Firebird "Eternity"
      Nov 2003
      Maine
      jag
      jag, i have used both old school and auto darkening, for extened welding i would use a old school, however i have used my auto darkening doing plenty of body work with no problems, long term i a cannot say anything about, but you do not get flashed from it.
      jake
      Nov 2004
      Eastern Washington
      Quote Originally Posted by 68protouring454
      Do you close your eyes with the auto darkening helmet for a moment?
      Jul 2002
      Muskegon, MI
      I just picked up an old school one yesterday for my girlfriend for $30.00. I must say shes doing a great job on her floors instead of me doing all the work. Cant wait to have her do the quarte panels real soon.
      I could never get myself to pay the money for an auto darkening helmet.
      England
      I used to get headaches from using an auto darkening helmet went back to old school type with no effects, also a mig glare is stronger than an ark welding glare by about 2 points on an auto shield.
      paul67
      Nov 2004
      Eastern Washington
      If I went old school, any one have suggestions on one with a large viewing window?
      True there is nothing faster than the speed of light.
      However, it is exactly that (the light from the arc) that triggers the auto-darkening lens. Good ones react quickly enough to prevent enough light energy (photons) from reaching the retina to cause any harm.
      Here's a way to check: stare at a bright light. Then look away. See the afterimage? That's what happens when your retina is saturated with photons. Do you see afterimages when you use an auto-darkening helmet? If not, then you should be safe.
      I use two helmets: an auto-darkening one for MIG welding, and a cheap ordinary one (I have #9, #10, and #11 glass) for TIG welding.
      When I'm MIG welding, I position everything, tip my hat, verify my position by looking at the torch through the lens, then pull the trigger and weld.
      Now ... remember: you only have two eyes. If you are unsure of all the free advice you are getting here, consult with a welding professional. Or go to the Lincoln and Miller websites and ask there (they have forums there with experts assigned to support them).
      jp
      ​John Parsons
      Nov 2003
      Maine
      look away
      no i do not look away, i set torch on work where i want to start and then start, no turing or closing, with convetnional helmet i set torch/gun then close helmet and start.
      any napa will have a cheap convetional with a large viewing window for 30-50 bucks goodluck
      Nov 2003
      Paradise, Ca
      Quote Originally Posted by Kuhlryde
      Huntsman. They let you look down further than the Jackson does, and are alittle lighter. Be prepared to buy headgear for any of the manual HOODS as the ratchet mechanism wears out quickly. Cheap though.
      I've had my two Huntsmans for probably 10 years, one for MIG/stick and one for TIG. You'd get a kick out of what my MIG hood looks like, and I'd post a picture, but it's not exactly safe for work.
      Make sure to buy a good selection of shaded lenses. I have two each of 8-14, but you'd be good with 9-12 more than likely. Also, do NOT listen to ANYONE about shade selection. Everyone is different! I run a 9 where other guys would use an 11....and you might need a 12 for the same situation. There's also lots of choices in colors (and plastic or glass). There's blue, green, gold and (the elusive) black. Try 'em all. If you want to try black, I'll have to give you the part numbers...it took me a month to track 'em down. Hopefully I still have the part numbers!
      My only comment on the auto hoods is this: If you get into a situation (very likely on a car) that the sensor could get blocked, then you WILL get flashed. Get flashed a couple times and you'll want to pry your eyeballs out with a crowbar rather than sit there all night not being able to get away from the pain.
      Here's an "I'm an idiot story": In a production setting, I came back from lunch and was bullshi11ing with a co-worker, struck an arc (dual shield @ about 300amps) and finally realised THAT I DIDN'T HAVE MY HOOD ON. Didn't sleep at all that night, and my eyes finally were able to open, after the swelling went down, mid-day the next day.
      -Matt
      Miami, Florida
      Ouch
      Kevin.
      Nov 2004
      Eastern Washington
      Ok. Here is another question...another kink in the decision process. What is the best way for incorporating a respirator into the mask or process. I heard there were a lot of gasses (which I can understand) being given off of molten metals. I decided to try and better protect myself since I am still young. Better now than later.
      Jun 2002
      Long Island, NY
      Spedglas has an option for a respirator. The hood is also adjustable so you don't have to buy different lenses. The adjustable shade comes in handy when you're constantly welding in different lighting situations (such as under various parts of the car).
      Matt's story reminded me of another thing to consider.
      Only high-end helmets are certified for TIG use. Less expensive auto-darkening helmets will only work with a MIG welder.
      jp
      ​John Parsons
      Nov 2003
      Paradise, Ca
      http://www1.mscdirect.com/CGI/NNSRIT...07199&PMT4NO=0
      Comfy and cheap. Worst case scenario is welding galvanised steel all day....you're dinner will taste funny, but no ill-effects.
      Wearing one of these for welding well prepped steel is in no way necessary.
      -Matt
      Boring Oregon, go figure:)
      parsonsj,
      What's the difference between mig and tig that would require different hoods? Is it only the different number shade?
