    Results 1 to 9 of 9
      Nov 2011
      Riverton, Wyo,
      Firewall Smooooth,69 camaro any pics please
      I am probably going to start on my firewall here shortly, I was wondering if anyone makes a complete panel to weld in. I will running a ls3 with vintage a.c. I will also be running 6spd so need holes for master cylinder setup, Will the ls3 fit without the stock firewall being modified? Please shoot me some pics if you have any good advice, How about the hidden wiper motor setups?
      thanks
      Dec 2009
      Carson City, NV
      not sure what kind of car you got but ABC performance makes some nice A-Body ones. bought one for my 72 Chevelle and its a very nice fitting piece (havent welded it in yet) http://www.abcperformance.net/firewa...%20panels.html
      Nov 2011
      Riverton, Wyo,
      camaro sorry i channged it, i checked that site did not see any camaro stuff thanks for the help
      Feb 2010
      Corvallis Montana
      Nov 2011
      Riverton, Wyo,
      nice looks good, thanks for the pics
      Nov 2007
      northern california
      i wasnt able to find anything so we made our own-
      https://www.pro-touring.com/showthre...pocket-or-brow
      Scotts Speed and Custom
      norcal1320.com
      Apr 2010
      White Rock, SC
      Detroit Speed makes one for $80.
      http://www.detroitspeed.com/1967-196...-fll-plte.html
      I put mine in about a week ago and it looks good although I don't have any pictures now. It has a rolled lip at the top and I had to grind down about half way, then I used the closeout panel as a template to cut out the old firewall. I cleaned up the cowl area where the old firewall was and then plug welded the top of the close out panel to the cowl and then stitch welded the sides and bottom just like is shown in the pictures on post #4. $80 sounds a little pricey for a piece of 18 ga. but it was pretty close to fitting out of the box and I would go that route again if I had to.
      Steve
      1967 LS1 RS Camaro (Project "OVRBDGT");
      1968 350 Camaro;
      1969 Chevelle SS-396
      Nothern California
      I used the Detroit Speed panel but here are a few others. I have seen a few threads where they put the wiper motor in the drivers outer cowl panel.
      Mikes Custom Cars http://www.mikescustomcars.com/proje...album=1&pic=11 they have plates for both side of the firewall.
      Screamin Perfromance offer something, you will have to call http://screaminperformance.com/index.htm
      Guy S.
      68 Camaro LS1, T56, Forgeline WC3
      69 El Camino BBC 4spd A/C Cruise SOLD
      2012 Dodge Crewcab Diesel 4x4
      Cartersville, GA
      If you have a local metal supplier that will cut to your specs (such as Metal Supermarket), its easy enough to make a template out of poster board and trim it to fit with some shears. $80 bucks isn't much, but saving the shipping charge makes building your own less than 1/4 the cost...and you can tailor it exactly how you want.
      Joe Hinds
