      Melbourne, FL
      1st gen vent ball bezel
      Ok my original ac system was trashed years before I purchased my car. So I basically gutted the rest of it years ago. I don't plan on reinstalling the AC. My current plan is to use just the "vent ball" bezel that I plan to modify so I can mount some stereo tweeters in them. What parts do I need as a minimum to install just the bezels?? Can you use just the bezel and the mounting screws/clips?? Or do you need the part that attaches behind the bezel also. Any help would be appreciated.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Mountain Springs, Texas
      You can just install the bezels, no other parts are needed if I remember right.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Melbourne, FL
      Thanks. I found my old set of bezels and retainers. I see how the bezel is attached to the dash. Also, what are the original cast/pot metal retainers worth?? The repro are probably ABS plastic. My originals are metal. Decent shape. A little bead blasting, paint and new seals they would be good as new.
