Thread: What heads would you recommend?
07-06-2005 #1
- Apr 2005
- 155
89 Ford 302 HO, stock bottom end, E303 cam, have 1.6 RR's may go to 1.72 rockers or an F303, 725 Demon carb on a single plane intake with A 3-3500 stall. Would like to keep original style headers and my intake and may go with a nitrous shot. Looking for head recomendations, aluminum or cast rion. Something that will just bolt on for the most part. Thanks!
E303
Cam Style:Hydraulic roller tappetBasic Operating RPM Range:2,500-5,500 RPMIntake Duration 050 inch Lift:220Exhaust Duration 050 inch Lift:220Duration at 050 inch Lift:220 int./220 exh.Advertised Intake Duration:282Advertised Exhaust Duration:282Advertised Duration:282 int./282 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.498Exhaust Valve Lift with Factory Rocker Arm Ratio:0.498Valve Lift with Factory Rocker Arm Ratio:0.498 int./0.498 exh. liftLobe Separation (degrees):110Intake Valve Lash (in):0.000Exhaust Valve Lash (in):0.000Computer Controlled:NoGrind Number:M-6250-E303CARB EO Number:D-225-16
F303
Cam Style:Hydraulic roller tappetBasic Operating RPM Range:2,800-6,000 RPMIntake Duration 050 inch Lift:226Exhaust Duration 050 inch Lift:226Duration at 050 inch Lift:226 int./226 exh.Advertised Intake Duration:288Advertised Exhaust Duration:288Advertised Duration:288 int./288 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.512Exhaust Valve Lift with Factory Rocker Arm Ratio:0.512Valve Lift with Factory Rocker Arm Ratio:0.512 int./0.512 exh. liftLobe Separation (degrees):109Intake Valve Lash (in):0.000Exhaust Valve Lash (in):0.000Computer Controlled:NoGrind Number:M-6250-F303Money, girls and cars...big ol' long cigars!
1964 Mercury Comet
90's 302HO, F303, Vic Jr, AFR 165's, 650DP, full roller, full MSD, WC T5
18x8 245 up front, 18x9 275 out back
KYBs, sway, 620 coils, stiff leafs relocated inboard
13" Late Model Cobra Brake Setup
07-06-2005 #2
New to Pro-Touring
- Jul 2005
- 2
AFR's are the best for a small block ford, I put a set on my gen1 lightning and gained 85hp at the rear wheels with nothing else.
07-06-2005 #3I'll second the AFR heads as top of the line.
I built a 392 stroker with a fairly small cam (255@050) and made well over 600HP @ the flywheel in a roadrace car
Cam wise I would be looking at something in the 230@050 range with a wide 112 to 114 Lobe Seperation.
don't worry about the lift, its not that important.
Take a look at the CompCams 35-556-8
http://www.compcams.com/Technical/Se...umber=35-556-8
In general I would stay away from 1.7 rocker arms... more problems than they are worth
I will give you this warning - the weak link on all smallblock Fords is the connecting rods. Stock they are cast and WEAK. Plan on going though the bottom end of the motor before getting too crazy1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
07-07-2005 #4
- Apr 2005
- 155
I figured AFR's would be the best bet. They are a bit more expensive, but pretty much just bolt right on with the 165 pedestal mounts. The Twisted Wedges come out on top on all that I have read, but AFR's come a close second on all too.
The bottom will be gone through for sure down the road. Want to play around with the nitrous first. Would rather grenade an old bottom than a new bottom.
That site didnt give any cam characteristics, like power band, etc. Do you know what they would be?Money, girls and cars...big ol' long cigars!
1964 Mercury Comet
07-07-2005 #5I would say that you are looking at a power band of approx 2000-6000RPM with that cam.
It will be pretty smooth at idle. Very wide torque curve1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
