    Results 1 to 11 of 11
      Janesville, WI
      LS1 T56 C4 Corvette project
      It pains me, but I have to admit I have lost interest in this project. It is nearly complete and has thousands of dollars in aftermarket parts. I just lack the time and interest to finish it at the moment.
      This was once a running LS1/4L60E swap. I picked it up as a basket case, and swapped to a T56. My intention was to have it be street legal, but track focussed. So the HVAC and dash have been deleted in favor of a more simplistic set up.
      I have more pics in the LS1 C4 and main albums (after the Buick pics) of my photobucket account.
      I have been very honest on the content of the car in my build thread:
      https://www.pro-touring.com/showthre...-56-Good-times!
      The short version:
      1984 Corvette - Cowl hood - from texas - clean
      1998 LS1 w S&P stand alone harness (C5 accessories)
      New Dewitts LS1 swap radiator
      Liberty face-plated T56 6-speed (w C4 C-beam bracket)
      Dana 44 IRS with aftermarket, fully adjustable Banski control arms
      Laser cut aluminum dash with Auto-meter guages
      New C5 front brakes, all new hub/bearings
      Racetronics fuel pump - new classic industries line
      New swap headers and Magnaflow mufflers
      17x11 front and 17x13 3 piece wheels (made by the founders of CCW)
      What still needs to be done:
      -Engine mounts (included is a slick engine plate set up)
      -Wiring (keep in mind the S&P LS1/T56 harness is a stand alone unit)
      -Interior - no seats (have door panels and carpet, but was planning on going the stripped down style)
      -Completion of fuel system (hard lines to engine)
      Other bits:
      New hubs all around, new rotors, new fuel pump, water pump, oil pump, hoses, etc
      The only parts that needing purchase that come to mind are a battery, clutch line, fuel lines (steel to rail).
      Just picked up 2 Corbeau seats.
      PRICE LOWERED TO $9k OBO
      I have much more in it. If I cannot get at least that I will keep it to finish one day. Will consider trades (turn key only).
      PM me and I'll send my phone number. There is much more to this car than I have had time to type.
      -Shaun-
      -Shaun-
      L92/T56 Stalker 1711 pounds, LS power!
      73 Buick Century L92/T56 swap in progress
      Janesville, WI
      Any interest?
      Will consider trades for running cars. I just do not have time for another project right now.
      Plenty of guys on here w the know-how to finish this car.
      -Shaun-
      Janesville, WI
      $9k?
      -Shaun-
      Nov 2011
      London, UK / San Diego, CA
      How quickly are you itching to have it gone?
      Eric
      1969/72 Corvette Coupe - https://www.pro-touring.com/showthre...uring-Corvette
      454 Block / Heads For Sale - https://www.pro-touring.com/showthre...ads-SD-LA-Area
      Corvette Parts & Service:. www.vansteel.com
      Janesville, WI
      Quote Originally Posted by sokoloka View Post
      Not a huge deal that it goes this very minute. I just want to get focussed on other projects.
      -Shaun-
      Jan 2012
      Country Flag: Cambodia
      You should advertise this on the corvette forum but in the C1/C2 and or the C3 threads. A lot of guys might want to do a body swap as it is an easy conversion.
      Janesville, WI
      Quote Originally Posted by uxojerry View Post
      Really? A C4's frame is bonded to the firewall, floor and rear quarters. I would think swapping bodies would be a major under-taking.
      I think it would be cool if someone made a Cobra kit car using C4 suspension (the way they do w fox and later mustang parts). Anybody know of such a kit type frame?
      Last edited by subtlez28; 02-20-2012 at 07:21 PM. Reason: I removed the incorrect unibody term
      -Shaun-
      Aug 2001
      Connecticut
      they are not unibody, there is a full steel frame burried in the (giant) fiberglass rocker you crawl over to get into the car. It's not a hydroformed frame rail like the c5 or c6 so it is a lot taller, but it is a full frame front to back, joined in two sections in the rocker behind the door hinge area. (had one apart once for bad ideas!)
      Cool project for someone though, bump for you!
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Janesville, WI
      Quote Originally Posted by 68sixspeed View Post
      You are right. Unibody is not the correct term.
      I am familiar w the C4's structure. What I meant is that it isn't a matter of unbolting some body bushings and dropping on a C1,C2 or C4 body. The C4 body, floor and firewall are bonded to the frame. I found a nice diagram of its structure, but I'm not sure how to post it here.
      -Shaun-
      Janesville, WI
      This is getting slightly off-track, but, here is a video that will give anyone interested an idea of the C4's structure and frame:
      http://www.youtube.com/watch?v=UfpQTAFoTU4
      I want to try this in the worst way. Imagine all that weight loss, but with corrected spring rate, alignment, and LS1 power!!!
      -Shaun-
      Janesville, WI
      Bump
      -Shaun-
